So I have been working on this bike for a while now and she starts up great when the choke is on. But when I push in the choke all the way it acts like it doesn't know if it wants to run or not. I doesn't die but it runs great for 2 seconds at 1K rpm then acts like its going to die for 2 seconds and it just repeats this cycle. I have the gauges on the carbs and their all at the same. I do notice that when I give it gas the compression is twice as much on the 1 & 2 cylinders. but 3 & 4 struggle to keep up. What do you guys think this might be? I'm thinking its maybe an air leak some where? Or maybe I need to take the carbs off and adjust the jet needle to run a little richer on the 3 & 4th?
Confused
For starters, your gonna have to pull the carb bank, pull the slide assemblies, float bowls, floats, pilot jets, main jets and emulsion tubes in that order and blow thru every orfice to make sure their open. Pay special attention to all the tiny sideholes of the pilot jets and emulsion tubes with a toothpick, no metal objects for cleaning of these brass components.
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top. -
Confused
To help your problems down the road, find and put in E0 gas (non-ethanol) in the tank. It is not so easy to find, but it is worth the effort to do so. You can run the normal E10 during the riding season, but do not leave the bike sitting for any length of time with that in it. If you do, you will keep having the same issue over and over. E10 is public enemy number 1 of anything carbureted.
If you like practicing carburetor R&R&Rebuild, leaving E10 in the tank will get you lots of experience.
E10 - What a Crock! Worse News - E15 is soon to be here!
Mike1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
MikeComment
As a side note, e15 will not be here for at least 4 more years. The agricultural act of 2014 prevents distribution of E15 until at least 2018.Howard
ZRX1200
BTW, ZRX carbs have the same spacing as the XS11... http://www.xs11.com/forum/showthread.php?t=35462Comment
thank god .whos bleeping idea was that anyway.e10 is a crock of crap you should see what happens when you park a car for a yearwhen you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
graybird78
80 sg (old faithfull)Comment
sounds like as others said you need to pull the carbs and do a complete cleaning. Get the enricher circuit in the bowl too and pull the emulsion tubes also. Clean everything! While apart, check the diaphrams for tiny pinholes, I don't know what symptoms the pinholes would have but my sx 750 has them and I need new diaphrams. the holes can be hard to see I checked them before and didn't see them.Jeff
77 XS750 2D completely stock
79 SF XS1100 "Picky" stock with harley mufflersComment
Ethanol enriched fuel was to be a pollution remover but actually when all things are added together it actually increases carbon output when you add in all it takes for production. What it has done is caused people to buy newer more efficient engines for weed eaters lawn mowers tractors cars etc because of the damage done and the aggravation of too much maintenance keeping them running with E10.
As an add on make sure you have fuel filters added to the lines. The new E10 not only causes carb problems but also causes more rust in any metal tank for transport or storage. Therefore more trash for the carbs. Its hell when you get it clean and one tank of trashy gas can stop it up again.To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
BTW, like I've stated in another thread, use of StarTron Enzyme treatment (1oz./gal) WILL resolve that issue if bike sits for extended times between uses.....BTDT, since the Bentley doesn't get regular riding duty.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
One little warning ,though.
If you leave the galvanized angle iron bar across the bottom of the carbs in place when you soak the bank of carbs, the Pine Sol will discolor it.
If you disassemble the carbs from the angle iron, then do not soak the angle.
CZComment
