79 xs11 special NOW Electrical issues
    • 8061
    Originally posted by tyhodge07
    I'm not finding anything on this. Do you have a link or another search I can do.
    • tyhodge07
      • Jun 2014
      • 73
      • Indianapolis, IN
      Thanks.
      I found this, is this the rebuild minus the plastic piece for it.
      http://www.z1enterprises.com/ItemDet...item=KL18-5100
      79 SF
        • 8893
        That is the correct kit above for the octy, the plastic center piece does not come with any of the kits, you have to reuse your own original one.
        • tyhodge07
          • Jun 2014
          • 73
          • Indianapolis, IN
          #34
          Awesome. I'll open mine up and see whatz going on before I order. Does the plastic piece go bad often, just asking to see if it should be something I expect when I open it.
          79 SF
            • 8061
            Here are the rebuild instructions:
            http://xjbikes.com/Forums/viewtopic/p=219609.html
            • Hak
              • Jan 2014
              • 124
              • Geneva, Ill.
              #36
              I got some DCC Clubman bars on mine. They have a HUGE selection of bars, I really love the position the clubman's put me in. I think clip-ons would be too low, even with risers, and doesn't that also increase vibration felt? The clubman's fit really great, coming up around the gauges then dropping down. I also put bar end mirrors on mine
              Pretty sure it was these
              http://www.dimecitycycles.com/7-8-in...andlebars.html
              Here's a quick snap
              81 XS11 Special
              • tyhodge07
                • Jun 2014
                • 73
                • Indianapolis, IN
                #37
                I was looking at them bars and ended up going with straight ones. If I don't like ill reorder the ones you have which was what I wanted at first them changed last minute.
                79 SF
                • Hak
                  • Jan 2014
                  • 124
                  • Geneva, Ill.
                  #38
                  Yeah for sure. The bar's are cheap enough! Nice thing about bikes, most everything is worth gambling even if you wont like it. Definitely post pics with the straight bars, I'd like to see how that looks. What kind mirrors are you going with?
                  81 XS11 Special
                  • tyhodge07
                    • Jun 2014
                    • 73
                    • Indianapolis, IN
                    #39
                    I was wanting a single on the left handle bar, but the fiance is wanting a pair mounted high. She thinks the handle bar ones look goofy. Not sure what she is thinking.
                    79 SF
                      #40
                      Hey Ty,
                      This is a kit on Ebay, it's showing the O-rings and 4 holed valve for 2 petcocks, along with the square diaphragm for the octopus valve! However, it's not from GeorgeFix.
                      http://www.ebay.com/itm/FUEL-PETCOCK...-/230950744686
                      This is JUST the diaphragm for the valve, it also apparently fits many other bikes as well.
                      http://www.ebay.com/itm/18-6633-Kawa...-/131152324426
                      Okay, found GeorgeFix's ebay store, here's his petcock/diaphragm combo rebuild kit:
                      http://www.ebay.com/itm/XJ1100J-XS11...-/360968853259
                      Here's his ebay store, Yamaha/carb parts section:
                      MOTORCYCLE PARTS FOR KAWASAKI, HONDA, HARLEY, YAMAHA, AND SUZUKI GOOGLE GEORGEFIX TO GO TO MY prostore FOR discount pricing PUT YOUR BIKE IN THE SEARCH BOX TO SEE WHAT I HAVE LISTED FOR YOU CB750 CX500 Z1 XS1100 GS750
                      • tyhodge07
                        • Jun 2014
                        • 73
                        • Indianapolis, IN
                        #41
                        Thanks for the links.
                        For the leaking petcock it was coming from between the tank and the petcock, I priced that gasket for a few bucks the octopus I was just going to do the rebuild kit on. I did try a little more gas in it yesterday and it didn't leak at the petcock, I was still going to order 1 gasket just in case. Getting excited for the handlebars to show up hopefully tomorrow. May get started on the seat this weekend also. Along with getting the battery charged and if all goes my way it will atleasr spin the starter. Fingers crossed.
                        79 SF
                        • Hak
                          • Jan 2014
                          • 124
                          • Geneva, Ill.
                          #42
                          Oh if you need one of those petcock rebuild kits let me know, I ordered 2 from mikesXS thinking I needed one per side, to find the kit contains parts to rebuild both petcocks and the octopus and 2 extra o rings I have no idea what are for lol I'd let you have it for a song if you want it. I removed the octopus on mine and added some quick connect lines to the carbs for easy removal
                          81 XS11 Special
                          • Meista007
                            • Feb 2003
                            • 107
                            • Ohio
                            #43
                            I'll take it if he doesn't want it...I just started to see some seeping from my right petcock and they haven't worked perfect in a while. I just haven't ordered the kits because I've had enough on my plate but I know it needs done (plus I will get a chance to shine them up)
                            • tyhodge07
                              • Jun 2014
                              • 73
                              • Indianapolis, IN
                              #44
                              Hey, thanks for the offer. I could use the left one (if they are even different) and can toss you a few bucks. Just one and pass on the other if you want. Thanks, this site has been great.
                              79 SF
                              • tyhodge07
                                • Jun 2014
                                • 73
                                • Indianapolis, IN
                                #45
                                Ok, got the battery charged and put back in. I have no headlight high or low, the push start does nothing. Can't check brake light or turn signals since I have them off. I jumped the starter and it engaged and did a slight turn and stopped. What do I need to look for to fix the stuff not working. Fuses are all good, grounds are good, etc. Would no turn signals and brake light prevent the button from working? And yes I am trying to start in neutral.
                                79 SF
