Quick Question: Bike pulls to the right?
  • Dylano*
    • Apr 2014
    • 202
    • San Luis Obispo, CA.
    So my xj pulls to the right, and my only guess is because I lowered the front end, and measured the distance between the lower and upper triple in a very rudimentary way (tape measure). Is that my issue? Maybe one side of the fork is a little higher/lower? Could it be anything else? I don't notice while just riding normal, but if I'm just cruising and let go of the bars, it pulls to the right noticeably.
    Have:
    1994 FZR600
    1982 XJ1100
    Had:
    1996 YZF600R
    2001 Honda xr125
    Suzuki race 80
    Honda PW 50
    Etc.
    Getting:
    1977 DT400
    • 3372
    Oh, then don't let go of the bars... Roads are crowned (high in the center, lower toward the shoulder for drainage) and you will have a right "pull" (gravity).
    I assume you don't notice it til you let go of the bars? If so, yeah, don't let go of the bars.
    2001 ZRX 1200
    1982 Seca 750
    1983 Nighthawk 550
    • James England
      • 3039
      • North of England
      A rudimentary measure isn't really where it's at. You need to get the forks exactly the same distance. I raised my XJR tubes (thereby lowering the bike..) by 10mm each side and didn't get it right the first time...same result as you...a pulling to one side. I'd get it exactly correct if I were you
      • Dylano*
        • Apr 2014
        • 202
        Well aware of that, it was the same result even on a road banked pretty good to the left.
        Have:
        1994 FZR600
        1982 XJ1100
        Had:
        1996 YZF600R
        2001 Honda xr125
        Suzuki race 80
        Honda PW 50
        Etc.
        Getting:
        1977 DT400
        • Dylano*
          • Apr 2014
          • 202
          Alright, I'll check them and readjust. That is what I was assuming it was. Thanks for the info.
          Have:
          1994 FZR600
          1982 XJ1100
          Had:
          1996 YZF600R
          2001 Honda xr125
          Suzuki race 80
          Honda PW 50
          Etc.
          Getting:
          1977 DT400
