XSives,
I want to clean a tank of rust, not bad but still.
I use 5% phosphoric acid and 95% methanol to clean the rust out of tanks before and leave an almost galvanized finish.
I'm not sure if this mixture will damage the fuel level float or any of it's parts (suspect it will).
Maybe I'll need to remove it and block off the hole ?
Any suggestions please ?
Thank You ! Done
Thank You ! Done
