79 Engine in an 80 Frame
  • Filter
  • 79 Engine in an 80 Frame
    Hello,
    My 1980 is not running the greatest. I know someone who has just a 1979 engine. What would I need to do/change to get it to work with my wiring harness?
    1979 XS1100SF with a Jardine 4 into 1, ZRX 1200 carbs, 82 XJ rear air shocks, ACCT
    SOLD - 1980 XS1100SG with a Mac 4 into 1, ZRX 1200 carbs, round 160 speedo, 82 XJ rear air shocks, ACCT
  • #2
    Nothing that I know of, the 78 thru 80's are essentially plug and play with regards to the ignition/wiring harness. It's when you try to put an 81/82 into and earlier frame or vice versa that problems ensue!
    • #3
      Re: 79 Engine
      Thanks for the info. Guess I need to go talk to my friend.
      • #4
        Look at my signature.
        It's a direct swap, no changes needed. I personally like the older carbs too.
        That 79 engine will feel a little boggy under 3.5 - 4.5K but when it hits that power band hang on.
        • #5
          What about the other engines make it better than the '79 in terms of bogging down in that RPM range?
          • #6
            The newer engines (80 -81-XJ) have a milder cam grind with larger valves. The 78- 79 engines have an aggressive long duration, high lift grind but smaller intake valves.
            They also have different timing curves to accommodate the different cams.
            • #7
              .....and of course TCI managed mechanical advance for timing and different TCI for 81's, and again a tottally different ignition for the XJ's.
              • #8
                Yes Brant, but that has nothing to do with the question he asked.
