Temperature gauge? yay or nay, or HOW?!
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    I've always like gauges on everything as well...for curiosity ive almost bought one of these multiple times, but I keep holding off
    Your one-stop-shop for all things Powered Paraglider and Powered Parachute
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
    • Dylano*
      • Apr 2014
      • 202
      • San Luis Obispo, CA.
      http://blueskyppg.com/index.php?main...roducts_id=214
      I know something very similar to that for much cheaper ill be back with a link.
      Yahman, awesome pics.... I'm using that idea for the 90° on that breather filter...
      Ray, great info, I'm no longer concerned! Haha
      Have:
      1994 FZR600
      1982 XJ1100
      Had:
      1996 YZF600R
      2001 Honda xr125
      Suzuki race 80
      Honda PW 50
      Etc.
      Getting:
      1977 DT400
      • James England
        • 3039
        • North of England
        Personally, in response to the question "why?", my response is "why not?" An electronic temperature sensor installed in the sump pan (on my XJR1300 there is a threaded hole, plugged off with a sump plug, especially for that reason)
        Oil temps rise if the level is low or if there is an oil leak. Given the risks of a sump sensor causing problems (no more than the standard oil sump drain plug), and the low cost, I'd rather know what temp the oil is at than not. I already hear the response "it's another thing to go wrong"... Yes, it is. If the gauge packs in, it's not exactly the end of the world. You chuck it out and buy another one.
        Having a gauge enables one to see the running temps of various oils too. IMO the more data one has about the running of the bike, the better.
        Here's mine on the XJR..... It's been on for over a year and is accurate (it self-calibrates every power-up) and has been extremely reliable.
        • b.walker5
          • Feb 2009
          • 1745
          • Invercargill, New Zealand
          The more guages, the higher the paranoia.
          Cant be bothered with all the extra bits to tell me if somethings going wrong. I'm not riding a race bike, so i dont need em. I'm riding a perfectly well engineered piece of kit that's designed to handle the conditions most riders, and conditions will give it. I check my oil at the start of a ride, and daily if a long ride, I use a good quality oil, and I listen to the engine for any changes. tells me all I need to know. If the engines running that hot that the oil is degrading, then it's too hot for me to ride, and I'll be in the pub.
          The only guage I actually need is the one that tells me if i'm gonna get a speeding ticket.
            • 7795
            Brian, is that If or WHEN??
              • 3932
              I'm confused James- So, the Japs use MPH instead of Metric KPH? Do only the Canadian models use the KPH speedos?
                • 7795
                James lives in the UK. They use MPH, NOT KPH, and the speedo reflects that. They DO drive on the "wrong" side of the yellow line, though.... (and yes, it does take about two days to get used to it!)
                  • 9980
                  Originally posted by Yahman
                  Where's the DVD player screen.
                  • Yahman
                    • Mar 2008
                    • 779
                    • Salem, OR
                    I have a mount there for my GPS also, but I try to limit my distractions to only three or four at a time.
                    Larry
                    82 XJ1100
                    80 XS1100G (Project bike)
                    64 Yamaha YA-6
                    77 Suzuki TS-185
                    • James England
                      • 3039
                      • North of England
                      No, it's hardly that. Paranoia is a serious psychological ailment and I have a great deal of sympathy for those unfortunate enough to suffer from it. In the case of having an oil temperature gauge, or not, I think it comes down to personal preference. I find it quite enlightening to see how terrain, riding conditions, altitude (always on the ground of course..) affect running temperature and, if one has that particular interest, a temperature gauge is the best way to indulge it. Bit like some people stick a small digital clock somewhere, so they know what time it is, rather than as an indicator of mental instability or undue worry... Easily fitted, easily not fitted, necessary, unnecessary,...whatever. I love mine!
                      • James England
                        • 3039
                        • North of England
                        The Japanese drive on the 'wrong' side too, I was surprised to discover when I lived there........ We're not the only ones.....
                        • Eveready1100
                          • 539
                          • Childers, Queensland,Australia
                          I fitted one to my Special a few years ago, and the most surprising thing I noticed was how quickly the oil temp dropped when I rode through a sudden shower of rain on a hot day.
                          Total cost of my setup was AU$ 16.90
                          CLICK for installation thread
                            • 3932
                            Interesting install thread. Thank you. When I was having issues with my alternator, I installed a slim LCD voltmeter. It's hidden by the key somewhere. Ideas like this are nice, but I guess I trust that everything is okay with proper oil level.
                            • Eveready1100
                              • 539
                              Oil level?? Want a bit of a read?? Click for installation thread
                                Dang Errol! You just keep coming up with good ideas!
