Vacuum advance frustration
  • PlanetMobius
    • May 2011
    • 15
    • Waukesha, Wisconsin
    Just picked up a 1980 XS11 Special. The previous owner said that he could never get it to run right. I took it home and cleaned the carbs and changed the plugs and did the basic stuff. I got it to start and it ran Ok but had a hesitation on the acceleration. Then I noticed that the vacuum hose to the timing advance was missing. I put a new one on but every time I connect it, the bike shuts off. what did the previous owner do and how do I undo it?
    • 7860
    Have you reset the timing? If not, you should start there. The factory service manual and/or the Clymer manual explain how to check the vacuum advance for proper function. You have the hose connected to the #2 carburetor?
      Mobius,
      The pick-up coil wires might be broken. If they are, when the timing plate advances and stretches the broken wires the engine will die because there's no signal to the TCI to fire the ignition coils.
      Pick-up Coil Wire Repair
      by Ken Talbot
      • PlanetMobius
        • May 2011
        • 15
        I will check both those things. Thank you.
          • 9980
          +1 on what 3Phase posted.
            .......and if broken, that'll be internally(try to stretch wire EVERY inch).
            Just for grins, I'm bettin' on the white wire, if any found broke internally.
              • 9980
              Ok, I'll take that bet. I'll take the orange wire for the win.
              $100 .............oops forgot the decimal .........$1.00
              • James England
                • 3039
                • North of England
                I bet you a rear left wheel bearing against $20 it's the white........ Wanna take me up on it.....?
