my comp.
Compression on the 79 after sitting outside for a couple of years with the rings rusted to the sides of the cylinders were as follows
#1 90 lbs. #2 125 lbs. #3 125 lbs. #4 135 lbs.
This was a cold engine, unlubricated.....with oil comp. rose dramatically.
By the way, I removed each sparkplug and gave each piston a sharp rap using a brass rod and hammer to free the pistons in the bores then used the kickstart to turn it over a few times then used the starter motor.
Bruce
Bruce
