Hey all,
Finally got the old girl running and running good!!! It has been a good year and allot of bucks but well worth it. I had a question about compression. Now that I have everything right, no oil running out the exhuast, no failing coils, new valve guides, She seems perfect. I checked the compression with the throttle open last night. I've got 180 of one and four and just over 170 on two and three. I thought the max was suppose to be around 150 or so. Chain timing is right on, valve shims are with in range. Is this something to be concerned about? I know shes tight but thats a big jump past the maximum based on my manual's specs. I thought once the rings seated in it would improve compression, but I don't have enough time on this motor yet for the rings to be seated in so I am just a bit confused.
