Syncing carbs and gas through leaking airbox
    Seeing he said "new territory", we were just making sure to give the correct method. Deviation from that is entirely up to the individual.
    BTW, you'd be surprised at how little the throttle plates are actually opened cruisin' at 4-5K out on the slab.
    • MarkD
      • Jun 2013
      • 488
      • N. Michigan
      JKL..., Reminder -- as you are syncing your carbs, use an electric fan trained on your engine as you work. This will keep it from overheating, as there will be other way to cool it.
      79 F
      1967 Suzuki X6 Hustler
      1973 Suzuki TM 125
      1979 XS1100 F
      2005 Kaw. Vulcan VN800
      1991 BMW K75
        • 9981
        Originally posted by tinman905
        I have the mega cycle cams and pushing close to 98 hp so I have to expect lower Mpg's for now but still working on it.
        Bigger cams = more air in the chamber that requires more fuel to burn/fire correctly.
        Simple fact.
        BTW, just out of curiosity. How much DID those 3 horses cost?
          • 8894
          The XS11 was rated 95 HP at the crankshaft, not at the rear wheel. We are lucky if we have 70 at the rear wheel. Tinman has 98 at the rear wheel, extra 25+ HP.
            • 9981
            Not exactly how the post read but OK. Still, physics remain the same.
            • tinman905
              • Aug 2007
              • 946
              • Orangeville,Ontario ,Canada
              Simple fact.
              Big Daddy Funk built the bike. I was lucky enough to have the chance to buy it from him. From what he has told me it wasn't about the money as he new it was going to be expensive plus he sold it to me shortly after. It was more about the experience. Having a friend that built race bikes and owned a dyno was a bonus and made it all worth while for him.
              I paid much less than he had invested , it came with a chain drive conversion, ZRX swing arm, rear wheel and a life time of spare parts. I already had a nice 80SG but couldn't say no to buying buying it.
              BDF Special
              • jkluczyk
                • Apr 2014
                • 28
                • Mount Prospect, IL.
                So, i got them pretty close. The backfires stopped. Revs are decent now.
                I dialed them in around 1100RPM for idle, but it would be good for a short bit, then sputter out
                If it's cranked up to 2K RPM, it holds...
                Also took it on a short ride around the block...my friend forgot to tell me there were not front pegs for it...so i have to wait for those parts...
                81 XS11
                1984 Honda VF700s
                1974 Yamaha RD350
                  See your gaining some...............but still gonna have to take two steps backwards, and likely have go thru the carbs a couple two three times........but you needed the practice anyways. BTW, no dicouragement, but your not even close to 'dialed in' as of yet...........and footrest ARE a good thing to have.
                  • jkluczyk
                    • Apr 2014
                    • 28
                    yeah...it's a good thing my honda vf700s never fails me...
                    But this should get it across town so i can work on it at my leisure.
                    81 XS11
                    1984 Honda VF700s
                    1974 Yamaha RD350
                    • jkluczyk
                      • Apr 2014
                      • 28
                      Thought I would add this after finally taking it for a quick spin around the block.
                      81 XS11
                      1984 Honda VF700s
                      1974 Yamaha RD350
