Hi all, I have a couple of carb questions, first, I've cleaned all 4 carbs, torn down almost completely and cleaned, and bench synched using the bread bag tie method and notice that when I do that the idle is way to high on start up, it'll jump to around 4k rpm, so I will have to bring it way down to have it idle at around 1100 rpm, and when I do that, the butterflys will be almost completely shut, not sure if that is normal or not.
Second, I notice that cylinder 2 is running cooler than the other 3, I noticed this when I saw the header pipes are purple-ish around the other 3 cylinders and #2 is still yellow, it is still hot, just not as hot as the other cylinders. While its running I will take the ignition wire off of cylinder 2 and it will create a misfire, so I know I have decent spark, spark plugs are newer, floats are set, only thing I haven't done is check the valve adjustment, but wanted to run this past the masses before I tear into that. It seems to run decent, I do have pods with velocity stacks installed as well, but this has been an issue even before that, carbs are with stock jets.
Third, what would you suggest for carb tuning/synching? Colortune? Old school mercury gauges?
Thanks for the input/suggestions!
