Walmart oil question
  • Winterhawk
    • Jun 2004
    • 684
    • Missouri
    Trust me, using an automobile oil with additives will eventually glaze your clutch plates and make your clutch slip prematurely.
      • 9980
      Trust me, I know Larry. Super tech has non.
        • 6760
        Originally posted by 3Phase
        Phil,
        Super Tech's good stuff, especially with 2K/3K oil changes.
        I was doing the every-other-oil-change routine to change the oil filter but when I got back home from the XS Southeast rally last year the oil filter media looked a little cooked and was starting to get fragile so I stocked up on WIX filters from O'Reilly's.
        I'm still thinking about whether I should change the filter during every oil change or try to stretch it to two and find the engine was force fed baked and flaked filter.
        I went to their website but i couldnt find them...all the search would give me was results for cars...NAPA does have them but they are not made by Wix
        1980 XS650G Special-Two
        1993 Honda ST1100
          • 9980
          You looking for filters Ben?
            • 9980
            Autozone SP2
            Napa 4933
            STP SMO-2
            Wix 24933
            Fram CH6002
              Like Greg said: WIX 24933
              You have to go in the store to order the filters at O'Reilly's. Their web site will just keep asking you to select a year/make/model of car, then tell you the part doesn't exist.
              NAPA oil filters are all made by WIX.
              NAPA PFI PS4933 (Power Sport)
              WIX 24933
                • 6760
                WIX 24933
                Ah thats it...would have to order them from NAPA as well or do they have them in stock?
                BTW I just picked up a 5 quart container of Walmart Super Tech 20w-50 for $12.72...
                1993 Honda ST1100
                  • 6760
                  Yes.............
                  1993 Honda ST1100
                    • 6760
                    Autozone SP2
                    Napa 4933
                    STP SMO-2
                    Wix 24933
                    Fram CH6002
                    Thanks Greg...
                    1993 Honda ST1100
                      • 9980
                      I order the Hiflo filters off ebay a 3 pack at a time. $20 or so and they last a season.
                      New filter at every change.
                        • 6760
                        well shoot that aint the cheapest deal...
                        1993 Honda ST1100
                          • 9980
                          Well, $8 each and delivered to your door. Find a better one and I want to know about it.
                            After you create an account at NAPA Online and select your local NAPA store, just put "PS4933" in the Search box and it'll tell you if they have one in stock.
                            If they do have one in stock, change the number of filters you want and it'll tell you the price or say, "Call Store for Availability" if they're not in stock at the local store. Jump through the all of the hoops to Reserve the filter for pick-up at the local store, then print it out like it tells you to do and bring the printout with you to the store.
                            You can also have the filters shipped to your house. I have not used the ship-to-home feature from NAPA so maybe you can be, like, a pioneer or a scout?
                            That so totally sucks pond water through a swizzle stick. I can't get that stuff here any more except in individual quarts if I'm lucky.
                              • 6760
                              Greg...how much better are they over the others?
                              Scott...thanks for the tips with napa...will see...theres a store 4.5 miles from me
                              1993 Honda ST1100
                                • 9980
                                Well I'll tell you Ben, I'm not an engineer. I'm just a cheap lazy azz and this is cheap and easy.
                                you'll have to do the technical research your damn self.
