ACCT Mod - What to buy?
  • Meista007
    • Feb 2003
    • 107
    • Ohio
    After reading through a ton of posts this seemed like a no brainer but after buying 2 that don't fit I'm just going to ask. I only plan on buying 1 more of these damn things and apparently I can't do it unassisted.
    Is there one I can buy that has the same size and bolt pattern?
    So far I tried the Raptor and the Vision. Neither of these are close even though they are listed as options.
    On a side note if anyone wants the worthless tensioner I already have they are up for grabs.
    V-MAx/Venture ARE plug'n'play.
    • Meista007
      • Feb 2003
      • 107
      • Ohio
      Thank you! That is the type of answer I was hoping for.
      I'm still gun shy after buying, waiting and failing twice in a row.
      Can I get validation that this part is what I'm looking for?
        My vision tensioner was barely off on the thread holes and with a few strokes of a round file it went right in.
          http://pages.ebay.com/motors/link/?n...441925&alt=web
          That's the 'correct bolt-in' tensioner, but be aware that even these sometimes need a little round file work to fit without binding on the bolts. Both the Raptor and Vision tensioners fit, but do need some file work....
          • ViperRon
            • Feb 2011
            • 1062
            • Woodstock, VA
            I used the tensioner assembly and gasket for a 660 Raptor on My 1980 and it fit with no change filing etc. It bolted on like it was made for it. However years ago when I got the original replacement part from Yamaha it I had to file some to make it bolt up straight.
            Rodan
            1980 G Silverbird
            1198 Overbore kit
            Grizzly 660 ACCT
            Barnett Clutch Springs
            R1 Clutch Fiber Plates
            122.5 Main Jets
            ACCT Mod
            Mac 4-2 Flare Tips
            Antivibe Bar ends
            Rear trunk add-on
            • James England
              • 3039
              • North of England
              I just fitted my second VMax ACCT. Both times, a very slight adjustment was needed with a round file on one of the holes. Half a dozen strokes of the file and that was it....
              • Meista007
                • Feb 2003
                • 107
                • Ohio
                Thanks for all that help.
                I'll pick up a rat tail while I wait for the new part.
                The Raptor bolt pattern doesn't look close when I eye ball it and the vision acct that I got second was closer but still seemed more than a couple strokes of a file away from fitting.
                Either way I have both if anyone is interested.
                  You did see this post in the 'modifications' forums, right?
                  • Meista007
                    • Feb 2003
                    • 107
                    • Ohio
                    http://www.xs11.com/forum/showthread.php?t=35501
                    Yes, clearly I saw that post and while it had a lot of information ultimately it wasn't direct enough.
                    This is a simple mod and a clear breakdown of the optimal acct to buy was all I needed. While some of them can be made to fit when they are all inexpensive and readily available I would rather just buy the best fitting/closest match. I'm not going to wedge something in there if there is a $20 part I can buy that fits.
                    That said the 2 I did buy can be had for the price of shipping if anyone wants to try and make them work. I'm just not comfortable with the fit and would rather use my stock tensioner or a manual replacement if I can't get one that fits.
                      • 8894
                      I fit a Raptor tensioner on a members bike recently and the holes were just a bit off. I just drilled both holes out with the next size larger drill bit and it fit just fine.
                      • Meista007
                        • Feb 2003
                        • 107
                        • Ohio
                        Yeah, I have read more then a few posts that say the same thing and I'm amazed every time because of the way the bolt pattern is rotated on the Raptor acct.
                        The good news is that even though I won't use it someone else may want to.
                          With changing of the tensioner, whatever your choice, you can't use the original tensioner's bolts as they are too long, and those are 'bottom holes. Some head castings in that area will have a little casting burr hanging out, and it won't actually be pulled up tight, and will leak....DAHIK. Just a couple precautions, along with making sure bike is on centerstand and timing indicator and rotation are done CORRECTLY before any removal.
