XJ Cams
  • D0wn5h1ft
    • Aug 2013
    • 515
    • Westerly, RI.
    XJ Cams
    Quick question. In the megacycle catalog it says: "XJ models - stock timing (more radical than XS stock models)". Does this mean that you can swap XJ cams into an XS11 for a more aggressive timing???
    Short answer, no. The XJ cams are the same as the '80-81 XS cams. While these have slightly more exhaust lift compared to the '78-79 cams, they have considerably less duration and are 'milder' in that they have better low-end power while giving up some at the top of the tach.
      • 4015
      Looking for any angle possible to win at the track Gabe?
      • D0wn5h1ft
        • Aug 2013
        • 515
        • Westerly, RI.
        Just wait until you see my next thread...
        Thanks for the info, Steve. I'm trying to see if there are any year of cams I can swap in to decrease the valve overlap. It looks like I'm going to be forced to pay $500 for some megacycle cams to eliminate the overlap...
