Screw sizing on carb?
  • jkluczyk
    • Apr 2014
    • 28
    • Mount Prospect, IL.
    Many of my screws came pre-stripped on my xs11 carbs. Anyone know the sizing of the screws that are on the top of the carb (that hold the diaphragm on)? So i can order form McMaster.
    Edit
    Found it: http://www.xs11.com/forum/showthread.php?t=37431
    '78-79 with cast tops: 8 - 6mm x 14mm (carb rail), 32 - 5mm x 15mm (tops and bowls).
    '80-82 with steel tops: 8 - 6mm x 14mm (lower rail), 24 - 5mm x 10 mm (tops and upper rail), 16 - 5mm x 15mm (bowls).
    81 XS11
    1984 Honda VF700s
    1974 Yamaha RD350
    Edit
    Could just go to your local Ace or Tru-Value in the specialty trays and buy the number of stainless button-head allen bolts. The two that hold the throttle cable housing piece will have to be a bit longer.
    • jkluczyk
      • Apr 2014
      • 28
      I could, but mcmaster is on my way home from work. Bulk packing and cheaper.
      81 XS11
      1984 Honda VF700s
      1974 Yamaha RD350
