Many of my screws came pre-stripped on my xs11 carbs. Anyone know the sizing of the screws that are on the top of the carb (that hold the diaphragm on)? So i can order form McMaster.
Edit
Found it: http://www.xs11.com/forum/showthread.php?t=37431
'78-79 with cast tops: 8 - 6mm x 14mm (carb rail), 32 - 5mm x 15mm (tops and bowls).
'80-82 with steel tops: 8 - 6mm x 14mm (lower rail), 24 - 5mm x 10 mm (tops and upper rail), 16 - 5mm x 15mm (bowls).
Edit
