Tkat fork brace----the end
  • newmaac
    • Dec 2002
    • 369
    • San Jose, CA
    Well, after almost 9 years and over 1200 of them, the end of the line
    may have been reached.
    My program disc has been reduced to magnetic origami. And worse than
    that, my back-up files are on a broken 'puter.
    As you know, these are done on a 3 axis CNC mill. Over the years, the
    program has been improved and tweaked as I've learned more efficient
    methods. All these changes are stored in programs on a floppy and
    inserted in the machine as required. All told, I think there were 9
    different programs/set-ups necessary to make a F/B for an XS1100 Spc.
    Yesterday, I finally got around to working on the X-bars for the XJ
    F/B's. There was one pgm I needed that was on the XS disc. I have no
    idea what happened but when I installed it in the machine's drive ---
    poof! ---disc error. "This disc is not readable. Please check and
    make sure the disc is installed correctly". All the info was gone.
    Pulled it out and tried another disc. All is fine. Then went to the
    office machine. No Joy. It gave me the same "unable to read" message
    and offered to reformat it for me.
    Basically, I'd have to start out from ground zero to recreate the
    product. The only 2 saving graces are:
    1. That I have the custom ground tools already.
    2. I have a few scrap parts around here that I might be able to
    reverse engineer.
    The bad news is that my old CAD system won't run on the newer O/S & w/
    the present economy I really don't want to spend half a month's rent on
    a new program.
    Realistically, how many more XS11's are out there that don't have the
    braces? Oh well, it was a nice run.
    Could I ask that someone post this to the XS forum also?
    Ciao,
    Tkat
    It can only be a sport if it has an engine.
    Everything else is only a game.
    Mike
    1980 SG "Angus"
  • John
    • 5117
    NOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!
    Say it ain't so!
    I don't have one yet!
    • strom
      • 1577
      • Slovenia, EU
      Doh! And I was saving up for one...
      I'm in puters tho... not data recovery... doh!
      .... and how am I gonna get one now... anyone selling theirs?
      LP
      • TheDjost
        • Jul 2003
        • 153
        • Montreal, Qc
        Where is T-Kat located? I do (did) computer repair/data recovery. Nothing is guaranteed in that field, but I did pull off a lot of "miracles" for very important stuff for some clients. Maybe I could help. Maybe try to walk him through a couple of procedures. I still have a couple of my data recovery programs on disk.
        Let me know.
        -Justin
        • newmaac
          • Dec 2002
          • 369
          • San Jose, CA
          Justin, he is in Santa Clara, CA.
          You can get him at www.tkat.com, I believe.
          Mike
          1980 SG "Angus"
          • petevan
            • Sep 2003
            • 35
            • Bountiful, Utah
            That sounds about right. Right about the time I was going to make a request for one the disk crashes. If you get it up and running again put me on the list to get one!
            • Jerry
              XS & TRUE XJ GURU
              • 3023
              • Elma, IA.
              I've recovered many files from damaged disks, and have recovery programs on my computer. I hope someone in the area can give it a try, but if all else fails, I'll askTkat for the bad disks and give it a go.
              Many times the problem is with a bad boot block or FAT problem; the files themselves are often OK.
              If recovered I'll burn the files to a CD.
              backup, backup, backup.....my critical files are on my hard drive, a Zip disk, and periodically written to a CD.....
              Jerry Fields
              '82 XJ 'Sojourn'
              '06 Concours
              My Galleries Page.
              My Blog Page.
              • Badger
                • Feb 2004
                • 27
                • Near Port Pirie in South Australia
                Oh No!
                No more Tkat.........it cant be..........once I got my current woes sorted, a brace of some sort was on the list, and if I couldn't find one here in Oz, a Tkat was my back stop............damn!
                Come on you computer wiz's, get on to it!
                • xswilly
                  • Jul 2003
                  • 462
                  • Hollis, maine
                  if your backups are on a broken computer
                  and the harddrive isn't the thing that is broke
                  pull the harddrive out of the broken computer
                  and put it into a working computer as a 2nd harddrive
                  also called a slave
                  you should be able to see your files then
                  also what type of cad system are you using
                  i'm using mastercam v9
                  and autocad 2000 & 2002
                  if you are unsure on how to put the harddrive into another machine
                  PM me and i can go into greater detail
                  http://home.securespeed.us/~xswilly/
                  79F Parts
                  80G Parts
                  75 DT 400B enduro
                  • Jerry
                    XS & TRUE XJ GURU
                    • 3023
                    • Elma, IA.
                    XSwilly...
                    Tkat's post was forwarded from another list; Tkat does not post here directly. You can contact him through his web page at www.tkat.com.
                    Don't think the problem is a hard drive, more like a bad floppy disk. Tkat is now, I think, in his '80s or close to it. He isn't much into computers.
                    Jerry Fields
                    '82 XJ 'Sojourn'
                    '06 Concours
                    My Galleries Page.
                    My Blog Page.
                    • graybird78
                      • Apr 2003
                      • 360
                      • council bluffs iowa
                      no brace
                      I still don't have one for my special either. always have to spend extra cash on something else.really wanted to get one toooooo. someone keep us posted.
                      when you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
                      graybird78
                      80 sg (old faithfull)
                      • Pat Kelly
                        • 3046
                        • Golden Valley, AZ
                        Besides the data problems could it be that Tkat is getting tired of making them? Maybe someone else with or has access to a CNC machine could take over production? Especially if they could use the data that Tkat already has (had).
                        Pat Kelly
                        <p-lkelly@sbcglobal.net>
                        1978 XS1100E (The Force)
                        1980 XS1100LG (The Dark Side)
                        1999 Suburban (The Ship)
                        1994 Dodge Spirit (Son #1)
                        1968 F100 (Valentine)
                        • chevy45412001
                          • Mar 2003
                          • 1412
                          • Jacksonville Florida
                          this may sound crazy?
                          Could'nt a part from a tripple tree be used for a fork brace?like the top or the bottom,cut off the part that goes through the frame of coarse grind or sand smooth to look good etc. I mean they are cast iorn aren't they?(would be pretty strong etc.) Just a thought.
                          1982 XJ 1100
                          • John
                            • 5117
                            The triple tree won't work. The fork brace clamps to the sliders below the dust seals. The triple clamps are only big enough to fit over the upper tubes. Good idea though.
                            • Bill__Woods
                              • 281
                              • Circleville, Ohio
                              I hate to hear the bad news, glad I got one a few years ago. Finding someone with a CNC to make them should be no problem. The problem is they would end up being Twice as expensive. The only way anyone can make such nice fork braces for a price as low as Tkat, is by forgoing any real profit margin (Labor of Love). I was looking in to having some different parts CNC machined and the price is high, unless you want them in BULK (5,000 to 10,000 pieces).
                              I have two very good friends that are Machinsits (Tool & Die makers) and they were impressed that I OnlY paid $75.00 Shipped for it. They both said they could not Duplicate it for the price, let alone Design & Manufacture at that price, unless they were making Hundreds of them.
                              If there is anyone on the list that is a machinist and could produce them, speak up, stand up,carry the Torch!
                              In my opinion, I belive the fork brace I bought off TKAT was worth Double the price that he charged me for it. The improvement it made on my bike was outstanding, fits perfect & looks good. it will look great when I polish it and clearcoat it.
                              By the way if you want to still get a TKAT Fork Brace - I think Merriam Cycles sell TKAT braces and has them in stock. All the people that were saving for a brace from TKAT - Keep Saving cause they cost more from Merriam than buying direct from TKAT.
                              This could be the beginning of the end for the XS1100.
                              Bill Woods
                              1981 Yamaha XS1100SH (Eleven Special)
                              1985 Kawasuki GS425 Mojave ATV
                              2006 Yamaha Wolverine 450 4x4 ATV
