Fairing removal questions.
  • alaskey2
    • Apr 2014
    • 271
    • 60940
    Hi guys, I have a 1978 Standard with a windjammer fairing. I got a headlight from a forum member and now I wanna get this monstrosity off.
    Question, as far as wiring goes..... what SHOULD I find when I remove it? There is a plug on the fairing's left hand side. I assume this harness is for headlight, and turn signals. Are their other leads as well or should I expect to cut the plug off and attach new bullets?
    I would like to have some idea of what SHOULD be there, I know how unreliable POs are...
    Thank you!
    78 E
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    Unplug the harness from the fairing then unbolt the fairing and remove. There may be a ground wire on one of the mounting bolts.
    Once you've got the sucker off, you should be able to trace the harness back to the individual plugs for the headlight and turn signals/running lights.
    Remember that all that needs to go inside the headlight bucket.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    • alaskey2
      • Apr 2014
      • 271
      • 60940
      is there a rubber grommet for the headlight bucket? Something to keep water away from all the wires?
      78 E
        No grommet....
          As stated, that plug is apart of the wiring harness for the fairing. If it was done correctly the harness unplugs from the factory connectors back inside where the headlight bucket should be.
          There may be a cup for the back of the headlight but there really should be a H4 headlight connector to plug into the headlight. It really doesn't get wet inside the bucket really that much.
          ฮผฮฟฮปแฝผฮฝ ฮปฮฑฮฒฮญ
          • mikubuilder
            • Jul 2011
            • 548
            • Westland, Mich.
            sometime there are two splices(usually blue clip ons), you just have to open those with a knife blade or screwdriver, but note which color goes where, or take few pics...you might decide you don't like buffeting that much
            Nick
            1982 Virago 750 (it's alive!)
            • jayel
              • Apr 2012
              • 152
              • Birmingham, Iowa
              wiring will probably be in a vinyl draw string bag, hope you have the plastic bits and rubbers for the fork ear to bucket bolt ups
              where are we going, and why are we in this hand basket?
              Iowa the Beautiful Land 1980 XS1100SG
              • alaskey2
                • Apr 2014
                • 271
                • 60940
                Thanks everyone! I will be sure to take plenty of pictures. For my own reference and to add to this thread.
                78 E
                  Alaskey2,
                  After disconnecting the fairing pig tail put it inside the fairing.
                  So you can find it after the first rain storm catches you on your lovely naked bike and you want your fairing back.
                  • alaskey2
                    • Apr 2014
                    • 271
                    • 60940
                    I live in Chicago. I go for 100 ft and the hit a red light for a minute. Farings don't help me in the rain. Nothing helps when you're just sitting still.
                    78 E
