Hoses, vacuum and otherwise.
  • mattfrme
    • Apr 2004
    • 19
    • Boston, MA, KC KS
    Hello All,
    Here is the update...
    The clicking noise that I heard is actually the pick up coil.
    I have taken off the cable and checked the OHM's, etc. Seems to be ok. When I reattached it, it seemed quieted, but definately still there.
    Any Ideas? Has anyone heard of this before?
    Other then ehis problem, bike is running great, I have already put about 500 miles on it with out incident.
    It is still a pain to get started, if it has sat for a few hours, it needs a squirt of started fluid. I am hoping that once I convince the pick up coil to stop the clicking sound, I can get the timing adjusted which will solve the starting problem.
    Thanks again for all the help,
    Matt
    the longer I live the more I appreciate life
    • CA.XSer
      • 188
      • Jerome, ID.
      Where is the vacuum hose hooked up to? It should be hooked to the #2 carb not to the intake boot.
      Gary
      79sf
      78e
      • CA.XSer
        • 188
        • Jerome, ID.
        Maybe this will help. The black hose goes to the Octupus, the gray hose to the advance unit.
        Gary
        79sf
        78e
        • CA.XSer
          • 188
          • Jerome, ID.
          Well that worked great!!!
          Gary
          79sf
          78e
          • mattfrme
            • Apr 2004
            • 19
            • Boston, MA, KC KS
            WOO HOO!
            Thank you all.
            I changed the vacuum advance hose to the correct place (and moved the octopus to its correct place) and the babe started right up, runs GREAT.
            Ok, now I know what you mean by ripping the arms off.
            Thanks for all your help, especially the picture!
            Matt
