Bike won't fire over
  • mack
    • 2411
    • Ontario, Canada
    I've been working on this little 650 XJ and have it all together. Dropped the battery in fully charged and it turns over great. I have spark and fuel in the cyliders but it just won't fire over.
    Questions:
    1. Could the cams be 180 degrees out of sync with the pick up coils?
    2. I have a meter but really don't know how to use it. If I wanted to check the ignition at the fuse box, how do I do that? (I replaced the old one with TC 's blade fuse box.)
    3. Is the TCI grounded separatelyon these. I did remove one ground wire but it actually screws into the air box then the frame. Can't tell what it goes to because it is so congested in there.
    Cleaned as many connectors as I can get my big paws on!
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • Old Red
    • Jul 2012
    • 290
    • Greenville, NC
    Sounds like it’s time to do a compression test.
    The Other Earl
    80SG, 81SH, 80 standard parts bike, 81SH parts bike
    and new to me 78 standard dresser
    • MPittma100
      • Aug 2011
      • 2359
      What all have you done to the bike? What have you had apart, if anything? Was it running before?
      1981 XS1100H Venturer
      K&N Air Filter
      ACCT
      Custom Paint by Deitz
      Geezer Rectifier/Regulator
      Stebel Nautilus Horn
      EBC Front Rotors
      Limie Accent Moves On In 2015
      Mike
      • mack
        • 2411
        • Ontario, Canada
        well
        I pulled the carbs and rebuilt them , triple cleaned them. Set the levels this morning and they are dead on. Pulled the cams and re-ser the shims. Only two were within spec. Changed out the original fuse block and put in TC'S. BUNCH OF OTHER STUFF BUT all none fuel or electrical.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
        • mack
          • 2411
          • Ontario, Canada
          this bike
          Ran last fall because i drove it into the shop.
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
          • nzemke
            • Sep 2012
            • 179
            • Moses Lake, Wash.
            Sounds like what my bike was doing...does it have the peg for a kick start? If so there should be an emergency kick start lever under the battery that will fit on there. Slap that on and give her a kick to see if she fires up. I must have spent three weeks trying to trouble shoot electrical and rebuilding the carbs from the ground up. Then on the first kick the darn thing fired right up! Not saying its a sure thing but worth a try
            79F with two parts bikes (78E and a 79F). Ran it for the first season all the way through the summer. more work to do this Spring!
            • mack
              • 2411
              • Ontario, Canada
              It's cool
              This was the little XJ 650. It's cool. I have it running now. Didn't realize you have to prime the hitachi carbs before the vacum supply will work. Stupid me.
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
