intake boot sealant
  • intake boot sealant
    What is the sealant/glue I've seen some people fix their cracked intake boots with? I'm in need of something similar for intake boots of an idle air control valve on another project.
    RTV Ultra Black.
      Or plasti-dip. That's what I've used for intake boots and rubber car parts.
        Black rtv was my 1st go to but I figured there might be something better. What is plasti-dip? Is it available at parts store?
          Adam,
          Plasti-dip is available in a lot of places: Lowes, Ace Hardware, NAPA, Pep Boys and others. There's a spray version and a 'dip' version in a can with a screw top lid; just have to shop around.
          Plasti-dip your motorcycle
            A word of advice, if I may.
            You must get the rubber clean, and not just wiped off with a rag. Think inner tube repair. Clean with acetone or rubber inner tube cleaner, sand to roughen up the surface, clean again, and then apply.
            CZ
              3M super Weatherstrip this stuff stick to and holds almost anything
              http://solutions.3m.com/wps/portal/3...glDQW4G37S0Bbl
              where are we going, and why are we in this hand basket?
              Iowa the Beautiful Land 1980 XS1100SG
                Another thing to do is smear a bit of RTV or similar between the boots and head. I think this is an often overlooked area for leaks. Also some dielectric grease or Sylglide where the carbs join the boots. Makes them far easier to put together and will seal any minor vacuum leaks there as well.
                Living to EXcess.
                1979 XS1100F Canadian, stock exhaust. Top end rebuild in progress.
