Hi all. I'm just testing the neutral switch off the bike. Am I right in saying that an ohmmeter, with a prong held onto the screw that the wire attaches to, and the other held on the body of the switch, should show a difference in reading when the little plunger on the switch is pushed in? ie no resistance when the plunger is pushed? I'm getting absolutely no difference in reading at all, so I'm wondering if the switch is no good?
Neutral switch
Neutral switch
XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Tags: None -
Here you go, James---
79 F
1967 Suzuki X6 Hustler
1973 Suzuki TM 125
1979 XS1100 F
2005 Kaw. Vulcan VN800
1991 BMW K75 -
Thanks for that. It looks like an ohmmeter should change reading when the plunger is pushed. It's not ding that so I reckon the switch is no good. I just bought a new one.....XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Checked mine-- bad; got one from Andreas. Proved to be a goodie-- Neutral light is a go.79 F
1973 Suzuki TM 125
1979 XS1100 F
1991 BMW K75Comment
