Yep they're the brass type.
I tried a bit of heat to see if the fuel would vent off, to show me where they're leaking and to evaporate the fuel out, this worked Ok whilst there was fuel in the float as it wicked the heat away, but as soon as the float was getting dry inside the heat was too much and the solder let go, I'm going to try re-soldering the least damaged float, I have one spare float.
They're an old set of carbs that I was building up as a spare set so no urgency getting them finished, I've been given a wrecked set of XS750 carbs, they have similar floats but are wider, a cut and shut job on them may be easier.
I know that may make them float lower/higher, but as long as I set the fuel levels as you showed, rather than rely on float heights it should work.
I'll look into the newer type floats too, thanks for the info.
on the float hanger right next to the float as a heat sink before you put the float back together. The float'll fall right off the hanger, probably just as you finish sealing the seam, and it's not easy to put it back on the hanger and align it correctly without messing up the solder in the float seam or adding too much solder.
