Final drive mate up
    • 9980
    Use the IMG code Doc.....
      • 3918
      Who's beautiful OEM exhaust is that?
        Hey Greg,
        SORRY, I didn't see your post until after I editted his!
        Doc, that gap does look excessive! I'm wondering if the inner race of the left side bearing of the wheel is hanging up on something inside the rim??
          • 8797
          If something is wrong, the axle will bind when tightened to 100 ft/lb and/or the hole for the cotter pin in the axle will not be at the correct depth in relation to the castle nut. JAT
          Also, the spacer in the bearing in the pic in post # 4 does not look like the correct one, it looks too fat or it is in backwards.
            • 9980
            I went and looked at mine earlier and it looks about the same. 1/16" to 1/8".
            If it isn't binding or making noise I would say it's OK.
