Vacuum Lines
  • TheRev
    • Jun 2012
    • 235
    • Madison, Wi.
    Vacuum Lines
    Hello All
    I have a couple questions. I have a 79 xs1100 standard without the fuel octypus. I know the vacuum advance goes to the port on the number 2 carb body. My question is what do I do to the vacuum ports on the carb boots? My hunch is that I just cap them off but I'm not quite sure. I believe I will need them open to do the carb sync. Also, where might I find the caps? One last question, I don't have my digital dash hooked up yet, nor do I have a working OEM dash. However, I want to start the bike for the first time since I began the rebuild two years ago. My question is, without a oil light to warn me how can i make sure the oil is pumping up to the top end?
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
    The standards do not have the octy, they have vacuum operated petcocks. There needs to be a vacuum line run from the forward facing nipple on the petcock to one of the nipples on the carb boot (usually left petcock to #2 boot and right petcock to #3 boot). You can cap the other 2 boots off.
    Those boot nipples are where you hook up your sync tool. Those caps can be found at any auto parts store. They are just vacuum port caps.
      • 9980
      You can use a test light as a makeshift oil light. Clip the test light lead to the connector on the oil sending unit and the other end to power. The light will be lit. If it goes out once the engine starts you have oil pressure.
        • 9980
        Correct, I forgot about that question.
        You can get caps that will work at any auto parts store. The yammi dealer has the good heavy ones though.
        • MPittma100
          • Aug 2011
          • 2359
          Vacuum Lines
          If you want the original type vacuum caps:
          http://www.mikesxs.net/product/48-1447.html
          1981 XS1100H Venturer
          K&N Air Filter
          ACCT
          Custom Paint by Deitz
          Geezer Rectifier/Regulator
          EBC Front Rotors
          Limie Accent Moves On In 2015
          Mike
            • 9980
            $2 each
              I dont think there are any good rubber products on that site. certainly not "original".
                Originally posted by BA80
                $2 each
                More than that OEM..........and put them back in their packaging as they slipped off easily when hot. Went back to the heavy duty ones from NAPA....go figure.
                • TheRev
                  • Jun 2012
                  • 235
                  • Madison, Wi.
                  Awesome. Thank you all for the suggestions. I will try to figure out a test light. Thanks
                  1979 xs1100f
                  New Fuse Box
                  Progressive Shocks
                  Gold Valve Emulator
                  Dyna Coils
                  Electronic Flasher
                  Led Headlight
                  Led Turn Signals
                  2nd Gear Fix
                  Auto Cam Tensioner
                  Digital Dash
                  Stainless Bolt Kit
                  Maier Fairing
                  Spin On Oil Filter
                  Plasti Dip Rims
                  ISO Grips
                    • 9980
                    The OEM ones had spring clamps holding them on.
                      Yup.......and still did with the new OEM caps......no joy. I would imagine the 32yr.old spring steel has lost some of its return tension. Already having several of the other new vacuum caps, that was the quicker option at the time and just left it that way.
                      • TheRev
                        • Jun 2012
                        • 235
                        • Madison, Wi.
                        So I bought a test light today. So tomorrow I will hook it up. I just want to make sure I get this correct. I hook the test light clip onto the positive side of the battery and touch the oil sensor unit with the tip of the test light? Is that correct. The guy at the auto shop told me that the test light clip goes on ground not on power, so I am just a little confused. Thanks
                        1979 xs1100f
                        New Fuse Box
                        Progressive Shocks
                        Gold Valve Emulator
                        Dyna Coils
                        Electronic Flasher
                        Led Headlight
                        Led Turn Signals
                        2nd Gear Fix
                        Auto Cam Tensioner
                        Digital Dash
                        Stainless Bolt Kit
                        Maier Fairing
                        Spin On Oil Filter
                        Plasti Dip Rims
                        ISO Grips
                          Hey Rev,
                          The oil pressure switch is just to complete the circuit to ground. With the engine off...the spring inside the switch keeps the switch CLOSED so continuity, and you will see LIGHT on your test light when you contact the Negative Probe to the SCREW terminal of the pressure light switch. When the engine is running, oil pressure pushes the switch OPEN, no continuity, and therefore no path to ground thru that screw terminal, so NO LIGHT should be seen with your test light. Yes, the Positive end of the test light is to be connected to 12+V battery source. And just test the light by touching it to GROUND first to make sure it does light, then to the switch terminal screw/nut, it should still light with the engine off. You should NOT see a light with the engine running PROVIDED YOU HAVE OIL PRESSURE, and your pressure switch is working correctly!
                          • TheRev
                            • Jun 2012
                            • 235
                            • Madison, Wi.
                            So when I do my carb sync with a temporary gas tank that is non vacuum do I cap all the carb boots?
                            1979 xs1100f
                            New Fuse Box
                            Progressive Shocks
                            Gold Valve Emulator
                            Dyna Coils
                            Electronic Flasher
                            Led Headlight
                            Led Turn Signals
                            2nd Gear Fix
                            Auto Cam Tensioner
                            Digital Dash
                            Stainless Bolt Kit
                            Maier Fairing
                            Spin On Oil Filter
                            Plasti Dip Rims
                            ISO Grips
                              No, you need to have those uncapped so that you can hook your sync tool up to those.
