cheap float setting apparatus
  • vedgar
    • 311
    • Clarkston, Michigan
    You can make this for about 5 bucks and a couple zip ties. The funnel for filling the carbs is a turkey baster with the bulb removed. 1980 SG is now on the road and tuned for bear ! pm me if you need more details on apparatus assembly.
    79 1100 SF Carmine Red stock
    85 Honda v65 Magna
  • GNEPIG
    • Apr 2005
    • 1657
    • fl
    That is called the Manometer method, it's in the Clymer manual and it's a very precise way to set your floats (and check them).
      Are those fittings screwed into the bowls, or just pushed in? Are they leak-proof? Did you find them at the auto parts store?
      • vedgar
        • 311
        auto store vacuum connectors
        A little thread tape makes them leak proof and re-useable
        85 Honda v65 Magna
        • clcorbin
          • Jan 2010
          • 495
          • Albuquerque, NM
          When you are talking "leak" and "XS11 carbs", I think "leak RESISTANT" is the best you can every hope for!
          -- Clint
          • mikubuilder
            • Jul 2011
            • 548
            • Westland, Mich.
            I would like to see a bottom view of this set up...if possible
            Nick
            1982 Virago 750 (it's alive!)
            • vedgar
              • 311
              stay tuned for more.
              I will post pic
              85 Honda v65 Magna
              • vedgar
                • 311
                plastic vacuum fitting just screwed in lightly
                85 Honda v65 Magna
