Fuel tank lock
  • Mathh
    • Nov 2006
    • 696
    • Beek, Netherlands
    Fuel tank lock
    Hi guys,
    I'm reviving an 81 3X0 for a friend of mine. I installed an ignition lock with key I had lying around but the key does not fit the fuel tank lock. Anyone has an idea how to open it without destroying the lock? I know that, with the lock disassembled, I can get the ignition key to work with the existing fuel tank lock.
    Only question is how to open the fuel tank lid without destroying the lock....
    Because this information cannot normally be published on a forum (I know why., don't know what the mod thinks) I would appreciate it when you send me a personal message.
    thanks!
    Math
    MV Agusta Brutale 910R '06.
    Yamaha MT-09 Tracer '15 grey.
    Picks and a tension wrench.
    You could try sliding something relatively ridgid yet bendable into the front center of the of the cap recess area and try to hit the latch to pop it open. The latch move towards the rear when the key is used so it is very possible it would work.
      • 5073
      That lock should be easy to pick. I'll bet a locksmith could do it in 5 seconds.
      • Mathh
        • Nov 2006
        • 696
        • Beek, Netherlands
        Yup, sounds good, but ........ what is rigid and bendable?
        @skids: I bet you're right but none in my neighbourhood. And I ' ve been trying in vain for a couple of hours
          I am thinking a thin piece of sheet metal about 1/4 inch wide.
          • rdmcguy
            • Jul 2013
            • 515
            • Denver, Colo.
            gas cap lock
            Hey, how about a hacksaw blade or a feeler gauge?
            • red bandit
              • 970
              • central michigan
              A small knife blade about the size of the key, wiggle & giggle and it will open.
              79 SF parts bike.
                • 9981
                I've used a small curved seal pick to push the latch back on keyless caps many times. It's easy, just push down a little on the cap to take the tension off the hook and push it back.
                • D0wn5h1ft
                  • Aug 2013
                  • 515
                  • Westerly, RI.
                  Write down the four digit code stamped on the lock and take it to a lock smith. For around $15 he'll cut you up a new key to it. I've done this at least once on every Yammy I've owned because for some reason I like to lose keys like it's my job..
                  78 E - 2to1 exhaust, dynatek coils, special headlight [SOLD!]
                  79 F - gas tank refurb, headgasket change, straight pipes, late model carbs, virago lowering shocks, special headlight and gauges, TC fuse block, GSXR-1100 carbs (WIP)
                  "May my tires not fail me, nor my engine grow cold"
                  • The Lorax
                    • Jun 2005
                    • 1048
                    • Riverside, OH
                    If all else fails, use two small allen wrenches. Use them just like a lock pick set. It has worked for me in the past as I had my only key vibrate out if the lock while riding. The iggy switch wasn't an issue as it will turn with near any key, but I couldn't get the fuel tank open. Anyway I ended up taking the Lockett out for a while then bought a iggy switch and gas cap, installed the lockset into my gas cap and just used the key that came with the switch to run the bike now. I'll eventually change out the switch, but it works for the now, and oddly enough, latches into the switch when it's turned. Who'd a think it.
                    Have a nice day and tide safe :-D
                    '77 KZ400s (La Putana)
                    • Tat2demon
                      • Jun 2012
                      • 718
                      • Sioux Falls, South Dakota
                      I think I would save the time and head for a locksmith. I wouldnt want to take the chance of messing up the lock.
                      Nate
                      78 XS11 "Matilda" 2H7 000364
                      K+N Air Filter
                      88 Voyager XII
                      81 XJ650 Maxim
                        • 8062
                        Are you dealing with a cap that looks like this?
                        If so, I open it with a can opener that looks like this.
                        In the right side of this photo note the small tab sticking out from the lock. Put a little downward pressure on the cap and use the pointy end of the can opener to slide back the tab. It pushes straight back toward the back of the bike. Voila! It's open!
                          Since he is across the pond I guess I was assuming it was the recessed standard gas cap rather than the special gas cap.
                            • 8062
                            I just don't know. Regardless, what I posted might be of value to somebody.
                              Yup, better to ask and be sure rather than assume and be wrong.
