I've decidd I'm ready to try doing the tire replacement and balancing myself on my '80 SG. Done enough dirtbikes, I feel I should be able to acomplish the same thing with my street bikes. Have a question tho, about the brake discs. I know they're very fragile, and I don't want to do any damage while fighting with installing the new tires. Does/has anyone just removed the disc(s) from the wheel prior to removal/replacement of the tires? I imagine it would be a good idea to mark them, so I put them back on in the same place, but what do you folks think?
DIY Tire replacement
Nothing like a ride on a straight 4.
Or toying with death on my 1983 Maico 490 Spider. Only fractured 3 bones so far.Tags: None -
I wouldn't think rotor removal is needed. I would, however lay some thick cardboard or, an old blanket on the floor to protect the rotors. The 80 SG has slotted rotors, and they are stamped R or L, so they won't be confused, and there only 3 positions they can be installed. If you have dirt bike experience, then the XS shouldn't be much of a problem. Just don't go wailing on the wheels with a hammer.
I haven't tried this myself yet, but here is a pretty good article on changing your own tires. Motorcycle Tire ChangingBrian
remembering the same thing!Comment
I used a 14 inch tire rim with a split air hose around the bead for protection. The rotors fit into the rim and never get touched. To break the bead put 2x4 under the rim on either side to keep rotor off the floor.Gary Granger
2013 Suzuki DR650SE, 2009 Kawasaki Concours 1400, 2003 Aprilia RSV Mille TuonoComment
yeah, I figured that would work, but I just wondered if anyone had ever just takken the rotors off to avoid possible accidents. Of course, I suppose if I went to all that trouble to take care of the rotors, they'd end up falling off the workbench and warping or something like that! lol
I suppose I'll just stick to what's worked for others, and take my time... patience. Saves me every time I exercise it.
Or toying with death on my 1983 Maico 490 Spider. Only fractured 3 bones so far.Comment
I've never worried about the rotors, they are made of steel plates afterall. I've changed a number of tires by just laying the wheel on the back steps. Sometimes I have to use a bead breaker to get them loose though.
BTW, I found a cheap place to get tires, at the local Harley dealers. A lot of Harleys use the same size tires and they usually have some nearly new take-offs for $25 or so.72 TS185
77 XS750
78 SR500
80 XS850
80 XS1100 Midnight Special
81 Seca XJ750RHComment
I usually only work with the wheel sitting on an old tire not to save the rotor but to keep it from rocking when I'm woking the irons. If you do scratch the rotors, the pads will shine them back up.
The old gray biker ain't what he used to be.Comment
To make life very much easier, pick a sunny day and let the new tire sit in the sun a while.
Goes on MUCH easier.Comment
Must be nice to have sunny daysOriginally posted by Dragonrider
Gary Granger
I use a 20 gallon oil drum
with the top cut off
put some hose around the edge to protect the spokes
the brake disk should fit right in and the outside of the barrel hits aganist the spokeshttp://home.securespeed.us/~xswilly/
79F Parts
80G Parts
75 DT 400B enduroComment
