Xs750 r/r
    • 4015
    Xs750 r/r
    Turn signals were not flashing, headlight was flickering. Bike died upon activating turn signal. Alternator was swapped for the cover, found it easier to replace whole unit. Will do testing another day. Don't want to chase my tail throwing the other one back on though. Thanks.
    • 4015
    I should clarify: when I painted my engine, I swapped alternators with the cover as a whole. I remember testing it and it seemed within spec. Hmm, makes me wonder if the R/R is going . . .
    Battery was @ 10.5v when pulled.
      Stands to reason if it was working before you changed the stator and now it's not it must have something to do with the stator you installed.
      Maybe as simple as a bad connection.
        • 4015
        I'll report my findings in the morning.
          You're screwed because you let the magic smoke out of the original one..
          Unplug the alt wires and check from each pin to ground. (I like to use the stator cover) If you get any continuity, the stator is bad.
            • 4015
            So, I should see OL on each reading? Also, should I leave the black/green connector plugged-in while doing this testing?
              No. Unplug all wires going to the stator or you might get feedback from other components.
                • 4015
                Right, thanks Greg. I always have an extra R/R from one of my 750's I think if it's that.
                  • 4015
                  So, I believe it's the R/R. Ran the Clymer tests on the R/R, and I did not see the 1.8v (saw 1v) on the one test, and on the next test I did not see 14+v, I saw 12v. Ran leads across battery and revved the engine and did not see a change in voltage.
                  Feeler gauge on side of alternator had it stick. Does this mean I can rule-out alternator? .5 between each white wire, and 3.6 between black/green.
                    Plug in the other regulator you have and see if it works.
                      • 4015
                      Well, went back out there and put on the other alternator. Put leads across the battery. Instant voltage above 13v. I got my hopes up, until I saw the voltage going over 15v as I revved higher. Regulator gone bad stuck-out in my mind. A minute later I re-checked voltage and saw it slowly decline. Hmm. I hope it's just the R/R. My 750's are elsewhere, so I gotta wait to swap it out with a known good one.
                        • 4015
                        Xs750 r/r
                        Just bought a used R/R from a 750. However, it does not have the black wire on the smaller connector. Is that okay?
                          Should be; even the XS11 regulators don't all have that wire as Yamaha or their supplier deleted it somewhere along the line...
                            • 4015
                            Okay, great! Thanks Steve!
                              • 4015
                              So, just got home and decided to run another test on the diodes just in-case I missed something at the salvage yard. Is there any reason why sometimes I'll see readings on the pins, and other times nothing? I ran my leads across every single wire and got nothing on both of my Fluke meters. I put the R/R on the bike and see 14+v @ 3k rpm. So, disregard the readings, ride the bike and cross my fingers, or try with a different meter? The R/R I pulled from storage had OL across every pin, and now I'm wondering if my Fluke meter might be bad.
