Strange clicking noise from the drive shaft
  • Punisher
    • Aug 2013
    • 26
    • San Marcos, Tx.
    I began hearing these noises some time ago and assumed that the rear wheel bearings needed replacement. After completing the bearing replacement I am continuing to hear the clicking noises that seem to be originating in the drive shaft. Has anyone else had this problem that might provide some information on how to resolve it?
    80 XS11 1196 Wiseco kit, balanced crank,
    possible U-joint failing. Unhook spring retainer, slide back boot and by hand look/feel for any up/down movement in u-joint bearing cups. Also, accumilation of brown rust lookin' powder around joint or inside boot leads to suspect u-joint.
      More than likely it's the u-joint, but you may find this...
      • James England
        • 3039
        • North of England
        I read somewhere that the UJ joints used in the XS1100 are those used in a Datsun Sunny of the same era. That probably makes sense...Yamaha probably used readily available UJ joints in the shaft??
          I remember on here seveal yrs. back there was a certain fork-lift application that used the same u-joint.
            • 9981
            There is also a video from the Ausies about clicking in the rear wheel.
            HERE it is....
            • vedgar
              • 311
              • Clarkston, Michigan
              Bob Jones's advice on lubing
              About 10 years ago I had a chance to talk with Bob about the XS11. I had just bought my 79 SF and needed to know a little more about it as I didn,t know anything about it's faults of high points. Bob asked if I had lubed the rear driveshaft zerk. Being smug I said "oh Yeah", because I did grease it. He said ,"Don,t waste your time or the grease, pull it apart and hand grease with Moly. Bob is gone now butr the advice is still there.
              Vance
              79 1100 SF Carmine Red stock
              85 Honda v65 Magna
              • Briggs&Stratton
                • Mar 2014
                • 47
                • Grand Forks, ND.
                Is there a u joint readily available to replace with? I heard they were very hard to come by. I also heard about the forklift joint, but that it wasn't a direct swap.
                Anyone know?
                79 SF
                IG "9mmHeater"
                • James England
                  • 3039
                  • North of England
                  Anyone know?
                  I found some a couple of years ago but then didn't need to buy one. Definitely a Datsun Sunny
                    I saved a link to them, but it isn't a good link any longer. The U Joint Store was the vendor. I think BikerPhil came through with that link. They probably still have it.
                      • 2104
                      Anyone know?
                      Here's a few: http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
                      If you go with a used take it apart, clean and lube it before install.
                      • andreashweiss
                        • 951
                        • 180 mile northwest of Spokane,WA
                        ujoints
                        Good morning, I have lots of them, used, decent, cheap, if you need one, send me a private message. thanx andreas
