Headlight died...weeeeeeeee
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    I'm at work with my bike disassembled.
    Tested for power at headlight plug, nada.
    Checked fuses, all good.
    Generator puts out enough power for everything and headlight reserve unit was already removed last year.
    Next attack is my relay under the tank.
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
    • 8930
    Yep, the relay can be taken apart and repaired, it's usually just a broken solder joint. In the meantime, you can unplug the relay and jump blu/blk and red/yel in the harness plug and you should have headlight when the key is turned on.
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      What if you just keep the jumpers in?
      I used HID which takes almost no power to compared a standard bulb
      I keep getting work, so i havent gotten to testing that yet
      79F
      "Excelsior"
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      TC fuse block
      Raptor 660 Acct
        • 8930
        Yep, you can leave that jumper in indefinitely if you want, no harm. I've run mine that way for a couple of years, but with a standard H4 bulb.
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          Relay bypass worked like a charm...Time to take apart the relay and see whats up inside it
          79F
          "Excelsior"
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          TC fuse block
          Raptor 660 Acct
            • 4013
            I've never seen a bike with as many issues as Excelssior. Hopefully as soon as you get all these issues worked-out, it'll be a fine-running bike.
            • sparkfly88
              • Mar 2013
              • 585
              • CedarKey FL
              You must remember....I traded a shotgun for an abused ( what looked like ) bike...and a box of parts.
              thankfully this forum has been SOOOOOOOOOOO helpful in keeping this heap alive
              OH...and It's been my DD most of this time...its been wonderful!
              79F
              "Excelsior"
              Hid headlight 6000k
              Stock jets
              Shinko 712 F & R
              TC fuse block
              Raptor 660 Acct
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                Lookie what I found
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                  • 8930
                  An EZ fix, it'll be good for another 30 yrs.
                  • sparkfly88
                    • Mar 2013
                    • 585
                    • CedarKey FL
                    Well, I tried to solder it with a co workers soldergun...
                    It wouldnt stick.
                    Gonna use mine when I get home. Till then, its bypassed ( like everything else on this bike )
                    79F
                    "Excelsior"
                    Hid headlight 6000k
                    Stock jets
                    Shinko 712 F & R
                    TC fuse block
                    Raptor 660 Acct
                      • 2007
                      Hid
                      Sparky
                      How much difference does the HID kit make? I have been looking at some listings for those on Ebay and they seem reasonably priced. Just wondering about how much difference they make.
                      • Tat2demon
                        • Jun 2012
                        • 718
                        • Sioux Falls, South Dakota
                        I really like mine. Seems a bit brighter on the road, and definitely more noticeable to oncoming traffic.
                        Nate
                        78 XS11 "Matilda" 2H7 000364
                        K+N Air Filter
                        88 Voyager XII
                        81 XJ650 Maxim
                        • Tat2demon
                          • Jun 2012
                          • 718
                          These are the parts I got for it-
                          http://www.ebay.com/itm/AC-55W-2-5-M...item258adff147
                          http://www.ebay.com/itm/Diamond-Cut-...3a60a3&vxp=mtr
                          Nate
                          K+N Air Filter
                          88 Voyager XII
                          81 XJ650 Maxim
                            • 2007
                            been looking at this
                            http://www.ebay.com/itm/301123549721...%3AMEBIDX%3AIT
                              Hid bulbs need to be inside a projector housing to work correctly. Just putting a hid bulb on a regular halogen light housing is just going to blind everyone else as you drive. Don't be that guy.
