I ordered some bikemaster fork seals for my Special. Thes seals measure a little over a MM larger than the bore they are going into. I have destroyed the seals so far trying to get them to press in. Has anyone had problems with these. I have ordered the leakproof seals for it, because i have had good luck with them. These seals say they are 49MM.
fork seal question
fork seal question
1980 XS1100LG Midnight
1991 Honda CBR1000F Hurricane
A cold beer and another one!Tags: None -
Special seals are a different size than Standard seals. You apparently have tried to force the larger Standard seals in the Special fork leg which will not work.
Standard Fork Seal - 37X49X8
Special Fork Seal - 37X48X10.52H7 (79) owned since '89
+1........Special and Standard forks are two different sizes and IIRC two differnt manufacturers(KYB and Showia)
. Best in fork seal cases, stay with OEM, but know that no longer may be possible associated with the Special forks.
Last edited by motoman; 03-07-2014, 01:55 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Another faulty application listing. SH@#!1980 XS1100LG Midnight
A cold beer and another one!Comment
