Ok so I threw in a 120/90-17 about 2500 miles ago and my tires at the wear bar already. She's a DD and bt45 High perf. Tires are pretty soft. I had mocked up shinko 777 130/90-16 last time and they BARELY fit, I was definitely afraid of the swing arm rubbing the tire. TC'S write up says it's the right size though. So I'm confused why it's such a tight fit. Is it the shinkos low pro sidewall? It's almost impossible to find 120/90-17's and I can't even get the bt45 anymore. Thoughts?
79 standard rear tire
79 XS1100
fj1200 carbs
Dyna green coils
2nd gear fix
Frame cut w/ 06 nightster seat
RPM dual UNI pod filters, open headers
Clubman bars, drag specialties speedo, xj headlamp
Deleted fenders, Barnett springs
23 Yrs. old livin' life at 125mphTags: None -
I have no Shinko experience, but tire widths are rarely accurate. Of the tires I've measured, the Metzeler ran wide, the Dunlop and Pirelli ran narrow, and the Bridgestone was the most true to size. This was done on a 100/90-19 front tire. Rear tire measurements might yield entirely different results. All that being said, I would be surprised if any 130/90-17 rear tire failed to fit your bike. If it doesn't fit, I expect someone would have posted it to the forum.Marty (in Mississippi)
XS650E -
Try a shinko 712 rear 130/90/17, will fit between swingarm no problem, lasts about 6-7K with normal semi aggressive riding, about $60. JMHO2H7 (79) owned since '89
☮Comment
The tight fit is probably 'cause your installing a 16" tire on a 17" rim.Ok so I threw in a 120/90-17 about 2500 miles ago and my tires at the wear bar already. She's a DD and bt45 High perf. Tires are pretty soft. I had mocked up shinko 777 130/90-16 last time and they BARELY fit, I was definitely afraid of the swing arm rubbing the tire. TC'S write up says it's the right size though. So I'm confused why it's such a tight fit. Is it the shinkos low pro sidewall? It's almost impossible to find 120/90-17's and I can't even get the bt45 anymore. Thoughts?
1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
It's also possible that your swing arm may be over to the right side too much, it has about 10mm of adjustment from side to side, JAT2H7 (79) owned since '89
☮Comment
Hey Phil,
I've seen this statement a couple of times recently, but with regards to the tire rubbing situation, it doesn't make sense( to ME) ....the swingarm position should not affect the tire/wheel's position within the swingarm/final drive assembly. The tire will rub or not against the INSIDE edge of the swingarm depending on the tire's width. When it's mounted on the rim, and to the Final Drive, it's solidly affixed to the FD/swingarm assembly. Adjusting the swingarm sideways in the Frame/bearing supports will only move the entire swingarm assembly AND the wheel within it, but will NOT change the spacing between the side of the tire/wheel and the left arm of the swingarm where it narrows to allow the tire/wheel to spin past it!?!?
The only thing that I've found can change the wheel position within the swingarm assembly is to place some shims/washer UNDER/between the FD wheel hub that bolts to the wheel rim and the rim. That will position the wheel a few mm's to the right side...away from the FD and also from the left indented swingarm shaft.
Is there something I'm missing regarding the swingarm lateral adjustment?
T.C.T. C. Gresham
A 120/90-17 is too small for the XS, and that's one reason for the poor wear... Look here:
So schming..how would I have mocked up a 16 inch tire on my bike without having it on a wheel? As you know many people change rear wheel size to a 16 on the standards.
anyway I ended up grabbing a michelin activ 130/90-17 cuz I had a pretty massive amazon credit. So we'll see how it works when I decide to ditch the battlax. Idk if it's the tube in a tubeless tire or not but I think this tire wore so quick cuz I lost air quite frequently. Also to prevent future questions as to why I ditched the 16, it took 35 grams to balance the wheel
the PO had put on a 120 and I just wasn't comfortable with the hairs width of light between the tire and swing arm with the 130 but I know a lot of u guys say that's just how it is so.....If I crash from an exploding tire, thanks guys! Haha jk.
79 XS1100
fj1200 carbs
Dyna green coils
2nd gear fix
23 Yrs. old livin' life at 125mphComment
Also, I've never been comfortable with shimming the wheel hub? Idk if it's just me but it just seems the wheel hub only has about a half inch (straight guesstimation) of room that sits against the FD. Also I don't like messing with the bikes geometry too much by adjusting the offset of the wheel/tire. Nobody has had issues with shimming when it comes to feeling in a hard lean?79 XS1100
fj1200 carbs
Dyna green coils
2nd gear fix
From your first post, I got the impression you were trying to install a 16" tire on a 17" wheel. My badSo schming..how would I have mocked up a 16 inch tire on my bike without having it on a wheel? As you know many people change rear wheel size to a 16 on the standards.
Haha I was a mechanic for about 5 years. Worked for chappy nissan. I hope I'd know what a tire is and how they work. It's all goooddd
79 XS1100
fj1200 carbs
Dyna green coils
2nd gear fix
So, just S&Gs I will ask if you know that when switching from 17" wheel to 16" wheel you need to swap spacers, and brake arm as well.Life is what happens while your planning everything else!
78 XS750Comment
Hey Murphy,Also, I've never been comfortable with shimming the wheel hub? Idk if it's just me but it just seems the wheel hub only has about a half inch (straight guesstimation) of room that sits against the FD. Also I don't like messing with the bikes geometry too much by adjusting the offset of the wheel/tire. Nobody has had issues with shimming when it comes to feeling in a hard lean?
The shims are between the FD spline assembly and the Wheel Rim. The FD spline assembly still maintains FULL interface with the FD, it's just that the whee/rim is positioned a few mm's more to the right away from the FD. The FD spline assembly has the large O-ring/seal and such that engages/interfaces with the FD itself....the Rim is just there along for the ride so to speak. And I do a lot of aggressive riding, no difference in handling.
T.C.T. C. Gresham
Yes. Swap was done correctly. Also TC, yeah I know the FD spline remains with the fd. Just that it offsets the position of the wheel on the spline as u stated. I suppose even with it sitting slightly less on that spline doesn't matter cuz if you're gonna have issues with it. Being spaced a few mm's over is prob. Not the cause and the least of your worries at that moment haha.79 XS1100
fj1200 carbs
Dyna green coils
2nd gear fix
Yep, the washers under the drive would move the rim/tire over.
