Why is the Rear Brake Such a Pain to Bleed?
  • scalded dog
    • 458
    I just kept the pressure on instead of letting the pedal come all the way up, I would just pump it without letting any pressure off the pedal...
      • 4015
      Done! Funny thing is, I now have two speed bleeders I am not using. Put them on the front after they were rock-solid from reverse-bleeding them. Began to pump the brake and it turned mushy and would not firm-up. Put stock bleeders back on, reverse-bled and back to rock solid brake.
        had the same problem
        I had the same problem a few years back on my rear brakes. Believe it or not what finally worked for me is I rapidly pumped the brake pedal with my hand and bled the caliper. Did this several times and the brakes finally firmed up. No amount of slow or normal pumping ever did anything. I just stumbled onto the quick pump procedure. Of course now I am completely tearing into the entire front a back brake system to rebuild them again.
