Aftermarket Valve Springs
    • 4015
    I was at the motorcycle shop the other day when I bought the shocks, and noticed that they had an aftermarket box of valve springs and keepers from whenever. I think it said that they were heavy duty. The box was marked somewhere around $90. They were New In Box. Anybody have any interest in these?
    • 8963
    For an 1100?
      • 4015
      Hey Phil. Yes sir. If anybody is actually interested, I will go back tomorrow and take pics of the packaging. If I remember right, it was a red, blue, and white box. Everything was there.
        • 8963
        I don't need them, it's rare finding those tho.
        • D0wn5h1ft
          • Aug 2013
          • 515
          • Westerly, RI.
          I would be interested if I could get a set of valves to go with it...
          I've been wanting to redo my heads because there's a local place in town that I can just bring the heads to and they'll put new valves+springs in it for me. I don't need them to set valve clearance because I can do that myself. I'm just too scared to take out the valves/lap them/port the head/etc.
          78 E - 2to1 exhaust, dynatek coils, special headlight [SOLD!]
          79 F - gas tank refurb, headgasket change, straight pipes, late model carbs, virago lowering shocks, special headlight and gauges, TC fuse block, GSXR-1100 carbs (WIP)
          "May my tires not fail me, nor my engine grow cold"
            • 4015
            Well, I see there is a site that sells springs for less than $60, so I'm not sure how great of a deal those are, etc. Not too many machine shops that do head work are going to turn down a job, regardless if it's an XS11 or whatever. If you walk into a machine shop anywhere near a city that manufactures cars, you'll be walking into a shop full of cylinder heads as far as the eye can see.
            And, the reason for the head work is . . . ?
            Oh, I know! So, you won't be so far back in my mirrors on the track!!!
            • D0wn5h1ft
              • Aug 2013
              • 515
              • Westerly, RI.
              You know I sold the FZR to win this match and I'm not about to lose to no stock setup! What's another couple hundred dollars in head work for bragging rights?
                • 4015
                I'd take you down using my 1965 Honda Cub 50, lol.
                • mack
                  • 2411
                  • Ontario, Canada
                  Springs
                  "Kibble & White" sell XS11 valve springs. Just the springs though. I bought a couple sets a few years ago. Thats whats in the SF and LH.
                  mack
                  79 XS 1100 SF Special
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  https://youtu.be/wB5Jfbp6SUc
                  https://youtu.be/RaI3WYHSuWA
                  Frankford, Ont, Canada
                  613-398-6186
                    Valve springs by themselves usually won't give any performance increase unless the stock ones are bad. Ignition/cam timing will control where peak power is, so unless you change those to move the power curve higher in RPM and beyond the range of the stock springs they won't be needed. One exception may be endurance racing, but for street use they may cost you power by increasing frictional losses.
                    • mack
                      • 2411
                      • Ontario, Canada
                      Spring length
                      As always Steve, most helpful. I changed mine because my originals just didn't measure up.
                      mack
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      613-398-6186
                        • 4015
                        Btw, those were SW Valve springs by Monroe.
