XJ11 brake issue
  • GuinnessSynd
    • Jun 2013
    • 14
    • Midlothian, Va.
    XJ11 brake issue
    So I went to start the bike up to take it for a spin because we had a nice day here in Richmond, Va. After putting the battery in it started first time no problem. I went to take it off the center stand and I couldn't move it. Turns out both front disk brakes and the rear disk brake a locked solid. The rear brake pedal controls the back and the front as well. And of course it has the normal front brake lever on the handlebar. The pedal is really hard to push down, almost no movement. The is absolutely no pressure in the brake lever. I thought maybe the brake fluid leaked out but both MCs have fluid in them. I can't really afford to take it to a mechanic. Any ideas?
    82 XJ11
    Yes, the XJ has a linked brake system. The rear master controls the rear and IIRC the left front calipers. There is a small return hole in the master cylinder commonly referred to here at XS11 as the spooge hole. When dirt in the system plugs it up, the fluid can not return to the MC from the calipers. The result is your brakes stay on after you release the pedal. So your brake pedal has no movement because the system is already pressurized.
    The front MC controls the other front caliper. From the sound of it, that system is not working at all. But your front wheel will not turn because the rear system has the other front caliper locked on.
    Best solution is clean the calipers and the MCs of both systems. Most often a good cleaning is all that is needed, and you can reuse all the rubber seals. So all it cost is your time and some brake fluid.
    • CaptonZap
      • Jun 2010
      • 1748
      • Denver
      As a quick check to see if that is the problem, loosen and then tighten the bleed screw on each caliper. If some fluid comes out, and the wheels are looser, follow the instructions in the previous post.
      CZ
        Make sure rear brake pedal isn't hanging up on its pivot. Corrosion build-up/rust can restrict its free movement......JAT.
          Hi Matt and welcome,
          like the previous posts say; m/c spooge hole blocked &/or rear brake pedal seized on it's pivot.
          And even if you could afford to pay a mechanic it's highly likely that he'd know less about a 30+ year old bike than you do.
          • GuinnessSynd
            • Jun 2013
            • 14
            • Midlothian, Va.
            I am going to attempt to bleed and then clean the MCs and the caliper tomorrow . It will be my first time doing something like this. Any tips or suggestions?
            82 XJ11
              First remove the caliper from its mount, then you can use the master cylinder (push pedal or squeeze lever) to push the piston out of the caliper.
              On your rear system, do this for one caliper, remove the banjo bolt (bolt holding the line to the caliper) and I use a piece of rubber and a clamp over the hose fitting the banjo bolt goes through to seal off that line. Now you can use the MC to push the other piston out of the other caliper.
              As to cleaning, make sure you pull the seal out of the caliper (O-ring inside the caliper) and clean...clean...clean behind it. Get it as close to spotless as you humanly can behind there. That is the biggest reason for brake system issues on these bikes, gunk built up behind those seals.
              Pay attention to the position and direction of all the seals and components in the MC as you pull it apart.
              • GuinnessSynd
                • Jun 2013
                • 14
                • Midlothian, Va.
                so it looks like to left front bleeder valve was completely rounded from the previous owner. I tried pliers and grips and it wouldn't budge. Any ideas?
                82 XJ11
                • dpotter58
                  • Aug 2004
                  • 1842
                  • Southern Maryland
                  if you have a torch, heat up the caliper around it. hit it with some pb blaster or kano oil. grab it with some vise grips and turn it
                  1980 LG
                  1981 LH
                  • vedgar
                    • 310
                    • Clarkston, Michigan
                    Tap it with a mammer
                    Gently tap the top of the bleeder with a hammer before attempting to remove. Does not matter at this point if you mushroom the bleeder.
                    Vance
                    79 1100 SF Carmine Red stock
                    85 Honda v65 Magna
