European riding position conversion
  • TomB
    • Aug 2006
    • 967
    • Cumbria, UK
    Don't forget the rest of Europe ebay will have the same 5K7 footrests.
    I think you could easily fab up some similar rests, the 5K7 rests are bent steel rather than the 2H9/2H7 cast steel ones.
    Tom
    • TomB
      • Aug 2006
      • 967
      • Cumbria, UK
      If you got an old rusty lever and cut a 3" section out from 3" to 6" on your tape rule, the bend would end up where it should be, then paint black to hide join.
      OR.... these levers do bend easily with a bit of heat and do retain their strength once cooled, you could cut and weld the lever under the toe pad, then straighten the original bend and re-bend in the 5K7 place.
      OR.... Buy a 5K7 lever http://www.ebay.co.uk/itm/yamaha-xs1...#ht_2396wt_904 Description says a '78 but its a 5K7 lever.
      Personally, I'd rework the one you have, a lot cheaper option.
      Tom
      • TomB
        • Aug 2006
        • 967
        • Cumbria, UK
        If you're wanting to go for the complete Euro 5K7 look heres the fairing.
        http://www.ebay.co.uk/itm/Yamaha-XS-...8#ht_25wt_1190
        Includes the bracket. You'll need an 8" headlight.
        Tom
          • 2097
          Thanxs for the link Tom, I won the brake lever. Another piece of the puzzle secured.
          • rodwerx
            • Jul 2012
            • 19
            • White Oak, Tx.
            #35
            Tom
            Tom,
            Thanks for those pictures of the peg mount/brackets been trying to work out how to make some for 6 months.
            How thick is the plate steel that they are stamped from?
            I've made a mock up and would really like to know heavy the material needs to be.
            Thanks
            '80 XS11 Special SG, Black
            _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
            WOMEN are like BACON
            They LOOK, SMELL, and TASTE GREAT And slowly KILL MEN
            • TomB
              • Aug 2006
              • 967
              • Cumbria, UK
              #36
              I've just been down and put a caliper on them, 10mm with powdercoat, so I'm guessing 3/8" would be Ok but I wouldn't go any thinner as there is a bit of flex in them due to their design, they do go up and over and back a bit to get the rear set position.
              HTH
              Tom
              Tom
              • rodwerx
                • Jul 2012
                • 19
                • White Oak, Tx.
                #37
                Thank You James
                I would to take moment to thank James England for finding and shipping me parts that I needed to help me in converting my SG to a "1.1 Sport Imposter"
                THANKS
                Allan
                  • 8061
                  Show us the bike! We want to see it!
                  • James England
                    • 3039
                    • North of England
                    #39
                    THANKS
                    Allan
                    https://www.dropbox.com/s/rvr1f2l9rz...703_170124.jpg
                    You're welcome, Allan. No backache or painful wrists for you from now on then!
                    By the way, folks, I have a mother complete conversion set. Gearbox casing and linkage, alloy hangers, front and rear footpegs, brake lever. If anyone is interested just PM me...
                    • James England
                      • 3039
                      • North of England
                      #40
                      Oops. I meant to say 'another' not a 'mother conversion set'....!
