European riding position conversion
  • James England
    • 3039
    • North of England
    As many people here know, the European 'standard' riding position is different from the same model in the USA. The Euro footpegs are set further back which gives a more upright riding position, with feet further back and no backache. One of the big marketing things when the XS1100 first came out here was the ergonomics which allowed loads of miles to be covered in relative comfort.
    Because the pegs are further back, the alloy hangers and the footpegs themselves are different, the brake lever is shorter and the gearbox cover is adorned with an adjustable linkage to put the gearchange further back along the bike. Also, the handlebars are different although they aren't as critical to the riding position. Also, as a mere aside, the clutch inspection cover has three lines cast into it to complement the gearbox engine casing.
    Twice so far, I've sent all the necessary parts to two fellow XSives in the USA, for them to convert their bikes to the European riding position. In fact, FEDEX just picked up a box for one of our members.
    So...what I'm thinking is....if anyone over the pond who has what you refer to as a 'standard' model and wants to change the riding position from the somewhat laid-back, legs forward, back a bit bent position....I am willing to source the parts for you and send them to you, all at cost. I'm not looking to make any money out of it.....more do it in the interests of international relations and because us Brits let you have a little go in WWII and then ran off with our women by bribing them with chocolate and nylon stockings.
    So, if anyone is interested, just let me know. Here's some pix of the parts
  • DeanR
    • Jan 2005
    • 1499
    • Finger Lakes NY
    If I only actually rode my XS, I'd do this in a heartbeat James! Thanks for offering it to folks.
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
      • 2104
      James, I am interested in this conversion for my '79SF, and have done some research on the parts needed.
      Please correct me if I have my list, of parts needed, out of order:
      shifter cover and shifter linkage
      clutch adjustment cover
      chrome brake pedal
      footrests
      seat or seat cover and grab handles
      handlebars
      On my SF, I will have to fabricate the footrest mounting points as in the following pics, correct ?
      • TomB
        • 967
        • Cumbria, UK
        Careful there Schming, James is offering to send Standard footrests, you may need to specify that you have a Special.
        The frame you have pictured is a 5K7 (Euro Sport or RH in Oz + NZ) which is more like a Special, not a Standard, the two aluminium brackets will not swap over.
        I have sent 5K7 footrests over to one of the US members on here, "XS-play", you may want to ask him how he's getting on fitting his to his Special.
        Not quite sure why you'd need the finned clutch cover for different footrests
        Tom
        Tom
          There's more to it than just that....
          You'll need to cut off the OEM Special frame mounts and the brake pedal pivot to install the 'standard' muffler/footrest mounts, convert to standard brake linkage, and this will now prevent you from using the special exhaust because the mounts will be too low.
          If you want to retain the Special exhaust, you could modify the special mounts by drilling the 'new' holes for the forward footpegs, this would allow the brake linkage to remain, but the euro brake pedal will be a bit short. I'd also worry about the right side mount breaking with the added stress of the rider's weight transferred to the mount; these are known to break at the brake pivot hole already. A better choice would be to install a anti-rotation 'stop' on the frame (similar to the existing stop on the US models), that way you could use the Special mounts as-built, with only the brake pedal issue to deal with. Because the Special mounts the brake pedal pivot further back and up, the Euro pedal will be a bit short.
          Not an easy install on a Special....
            • 2104
            Yes Tom, I realize James post shows the Standard 2h9? footrest brackets,
            I don't need those for my SF.
            These footrests :
            I believe are correct for the 5k7 Sport which I'll have to fab the mounts for 'cause our models aint got 'em.
            I want the Euro style clutch cover 'cause we don't have it o'er here.
            This is what I'm lookin' to do :
            with this :
              • 2104
              Steve, I will be using the stock SF's footrest mounts so the exhaust will remain the same.
              The Euro brake lever mounts the same way the US models do:
                Look carefully at the parts fiche; it appears that the Euro Sport/RH aluminum mounts are the same as the US models, just the footpeg mounts are different.
                These look like they could be fabricated fairly easily, no frame mods needed, just a shorter brake pedal which could also be fabbed.
                You'll still need the shifter bits, but those can be gotten off any euro bike...
                You could probably do something similar for the standard, eliminating the euro pegs/mounts.
                • TomB
                  • 967
                  • Cumbria, UK
                  I don't need those for my SF. OK
                  These footrests :
                  No, they are the 2H9 footrests, they don't fit the 5K7
                  As good a reason as any
                  Tom
                    • 2104
                    Yes Steve, the Al mounts are the same.
                    Here's a pic of the Sport frame that shows the mounts for the footrests:
                      • 2104
                      Tom would you have a pic of the 5k7 footrests ?
                        I just want one of the round clutch adjustment covers with those ribs on it!
                        • James England
                          • 3039
                          • North of England
                          To clarify...the group of parts I posted a pic of are all 2H9 components which are compatible with each other since they were removed from the same bike....the 'standard' European XS1100 first released in 1977. We didn't get the other variants which were marketed in the US. Ours were, I believe, the E and F models which had the same alloy hangers, footpegs etc. Here's some pix of the parts in situ..
                          • James England
                            • 3039
                            • North of England
                            the ribbed clutch inspection cover mirrors the look of the gearbox cover and linkage on the other side of the bike. IMO it looks nicer than the flat USA version. It's a straight swap. Our engines were all black with ridges in alloy eg on the cam box cover, clutch cover and gearbox cover. The pj1 satin black case paint achieves 99% the OEM finish. The black engine look was quite radical at the time and was on all the European engines. All the other Japanese manufacturers had silver engines, so the factory black really looked something cool at the time.
                              • 4015
                              Hello XS community. I asked James to send me the Euro parts after falling in-love with his Black Beauty. James assured me that it was a seamless adaption of parts, so I bit. James constantly stayed in-contact with me, comparing pics of my bike, etc. to make sure everything would work. The pics shown above are the parts he's sending to me. The reason I asked for the clutch arm cover was purely asthetic. Also, the handlebars are rare, but I chose to stay with my superbike bars. I look forward to the arriving parts and painting everything. Thank you James for a valuable international service. An ambassador you are!
