Carb Synch and Enrichener Circuit
    • 9980
    I had mine turning 8000 in forth gear while climbing Pine Mountain. I rolled off the throttle and crested the hill at less than 60 mph. A state trooper was waiting at the top. Lucky day.
    I can't get 8K in 4th gear either, I have an 850FD so 4th is the same as 5th with a stock FD. Running the twisties in NC I'm in 3rd or even 2nd most of the time.
      • 7941
      Me too! My final drive is stock.
      • vedgar
        • 311
        • Clarkston, Michigan
        sf VS sg WARM UP
        my 79 sf warms up faster than my 80 sg. The 80 carbs have a leaner mixture screw setting from the factory than do the 79,s. Any one else on this one ?
        79 1100 SF Carmine Red stock
        85 Honda v65 Magna
          • 5062
          #34
          If it holds idle after it warms-up you are good.
          • MPittma100
            • Aug 2011
            • 2359
            Enrichment Circuit
            Agreed. Earlier 1978 & 1979 models warm right up. 1980 and 1981 models being leaner don't like the cooler temps, but are OK after longer warm up.
            Mike
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
              • 8797
              It all depends on your float/fuel level determining the engine's 'cold bloodedness' when cold starting. Also, if your carbs have leaky float valves, more fuel will drain down in the bowls from the lines/filters when the bike is shut off causing a cold 'no enricher needed' starting condition.
              • LoHo
                • Sep 2002
                • 1342
                • Fresno, CA
                #37
                It is funny how our expectations change. I am now looking for smoother idle and better mpg...a few months ago, I would have been delighted with "starts."
                  • 2083
                  Next thing ya know you'll be lookin to hard tail it
                  • LoHo
                    • Sep 2002
                    • 1342
                    • Fresno, CA
                    #39
                    I know this thread dried up a while back, but...
                    The bike idles great when warm. When I crack the throttle a tiny bit off of idle, it spits a time or two, but runs well after I get going. I can't help thinking she's a too rich, but my plugs say only a tad rich or normal.
                    Should I pursue synching again, float height, or something else? The engine and carbs are as stock as possible for a 45 year old bike.
                      • 9980
                      How old are your plugs? I need to put new plugs in every year or it'll start doing that.
                      • LoHo
                        • Sep 2002
                        • 1342
                        • Fresno, CA
                        #41
                        Just so y'all know, my initial investigation revealed a split in the vacuum advance hose. I guess at low vac levels, the advance would not move and the bike sputtered; at higher vac, it ran okay.
                          Glad you found the problem Larry! Could of been a tad lean on #2 from that split also. May wanna reset idle mixes and re-sync.
                          • LoHo
                            • Sep 2002
                            • 1342
                            • Fresno, CA
                            #43
                            I took the timing cover off and it was split in there, too. Replacing the hose improved things, but I'll bet the timing cover split existed when I tuned the carbs. Where's that damned Carbtune? Oh yeah, still attached to the Kawi that will never run....
