timing at 5200
  • Jdwags
    • 232
    • Rathdrum, Idaho (nort of Post Falls)
    timing at 5200
    Well, I got the mongrel runnin, and when checking the timing at 5200, i went way past the book's 38 degrees...
    is it the springs on the governor that are bad then? or anyone got another idea?
    also, i did the test with the vacum line attached?
    Thanks in advance for your input..
    jeff "Wags"
    Bothell, Wa
    79sf mongrel
    79sf rusty
    79 partsbike almost complete
  • MartyA
    • 2148
    • NW PA
    Hey Wags!
    Vacuum disconnected and plugged.
    Isn't the Special supposed to be 31 degrees?
    Marty in NW PA
    This IS my happy face.
    • Jdwags
      • 232
      ill try it again, and i gotta remember to check the supplement,
      my uncle found his original copy of the service manual, but the supplement for the sf wasn't out yeet..
      Thanks for the input
      jeff "Wags"
      Bothell, Wa
      79sf mongrel
      79sf rusty
      • MartyA
        • 2148
        • NW PA
        My mistake. Technical bulletin M79-018 states the XS1100SF timing should be 36 degrees, not 31 as stated in the manual, at 5,400 RPM.
        Marty in NW PA
