Intermittent rear brake problem
  • MPittma100
    • Aug 2011
    • 2359
    Rear Brake
    Since you are rebuilding the rear brake m/c and/or caliper, you should make sure that the brake lever is free. They will get rusty/dirty where it passes through the frame and stick - usually in the on position. Safe thing to do is take it apart, clean the hole and the lever, then apply grease prior to reassembly.
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
