Wiseco Big Bore Kit
  • James England
    • 3039
    • North of England
    Why would anyone advertise this way?????
    The same kind of idiot that puts a generic picture of several different pistons, along with a disclaimer that effectively says 'ignore the picture'. Totally daft.
      I believe the only rebuild parts still available are main bearing inserts and some valves, and those are spotty. Rod bearings are extremely hard to find (pretty much NOS that have been found in 'dealer kits' when on the rare occasions you do see them), same goes for 'genuine Yamaha' pistons and rings. I haven't seen a ring set in years, you'll see the odd piston or three on eBay once in a while in the various factory oversizes; try putting together a matched set....
      There just isn't enough market to warrant anybody tooling up to make replacement parts. Tony (geezer) at OMP had a short run of both early and late valve sets done and barely sold them all.
      • ViperRon
        • Feb 2011
        • 1062
        • Woodstock, VA
        80-81 Yamaha XS1100 1196cc Bigbore Piston Kits with Head Gasket XS1100BB -
        This is the over bore kit I got of ebay and installed in mine.It has run fine came in good quality and a much cheaper price than the Weisco or Yamaha kit. I do not feel that it is worth spending the money looking for power gain but if the lower part of engine is good and head maybe as cheap a rebuild as possible. There is always another solution also. If you can find good cylinders just re-ring the old pistons. The actual round cylinders do come out of the 4 cylinder assembly easily. So say you just have one bad cylinder just replace that one.
        Rodan
        1980 G Silverbird
        1198 Overbore kit
        Grizzly 660 ACCT
        Barnett Clutch Springs
        R1 Clutch Fiber Plates
        122.5 Main Jets
        ACCT Mod
        Mac 4-2 Flare Tips
        Antivibe Bar ends
        Rear trunk add-on
        • MPittma100
          • Aug 2011
          • 2359
          Big Bore Kit
          Since we all are so highly impressed with this "one piston" advertisement, I decided to send the following comment to that seller.
          "Why would anybody buy just one piston kit? Answer: Because he was mislead by your advertising showing a picture of more than one kit. It is people like you that give Ebay a bad name. I and all of my forum members now know of this scam. You can count on us buying piston kits from someone else when/if needed."
          The intention of my comment is to encourage this seller to redeem himself with an ad correction. We will see if I am wasting my time.
          1981 XS1100H Venturer
          K&N Air Filter
          ACCT
          Custom Paint by Deitz
          Geezer Rectifier/Regulator
          Stebel Nautilus Horn
          EBC Front Rotors
          Limie Accent Moves On In 2015
          Mike
            Don't hold your breath..... Makes you wonder if he has a incomplete set he's hoping to get rid of....
            • Dan Hodges
              Sensei of Internal Combustion
              • Sep 2004
              • 526
              • A garage in south St.Louis
              Cubic Inches
              A Wiseco 1179 big bore kit is worth over 10% more power all other factors equal. The latest Wiseco forgings have anti detonation groves and thinner rings (less ring drag) than the stock pistons and have a 6.6 cc dome and of course they are lighter than the stock slugs.
              It's also worth mentioning that the earlier Wiseco pistons for the XS were a different design and didn't have the anti detonation groves, trick rings and some other features the current pieces have and too make a long story short, the latest Wiseco pieces are state of the art but they aren't cheap and it's up to the owner of the bike as to what he/she want's.
              A head clean up with a valve job, new springs and OEM valve stem seals and the head is good to go.
              You will also need to have the block bored and honed (properly) by a shop that can finish the bores with the finish prescribed by Wiseco otherwise the rings will take forever to seat properly if ever.
              Again, if you are going to spend the money on trick pistons make darn sure you don't let some idiot dry hone your block.
              I had Advenced Sleeves in Ohio prepare my blocks but there are other shops who are equally competent.
              A set of early cams and the late head with the above parts will fetch 85 conservetive rear wheel hp with the stock carbs, Dyno Jet kit, stock air box and stock or similiar type mufflers.
              If needed, rod and main bearings can be found if you really want them but you might have to polish the main bearing journals of the crank to match up the correct clearences with the available bearings.
              Of course you can buy a junk motor from a junk yard and as long as it doesn't whine, jump out of gear, smoke or catch on fire you are good to go as long as you are not in a hurry.
              Happy motoring!
              • MPittma100
                • Aug 2011
                • 2359
                Big Bore
                Thanks Dan Hodges. Good information.
                K&N Air Filter
                ACCT
                EBC Front Rotors
                Mike
                • MPittma100
                  • Aug 2011
                  • 2359
                  Stock Rear Whel HP
                  Dan, what is the rear wheel horse power of these bikes in stock configuration?
                  (Quote) A set of early cams and the late head with the above parts will fetch 85 conservetive rear wheel hp with the stock carbs, Dyno Jet kit, stock air box and stock or similiar type mufflers.
                  K&N Air Filter
                  ACCT
                  EBC Front Rotors
                  Mike
                  • D0wn5h1ft
                    • Aug 2013
                    • 515
                    • Westerly, RI.
                    Yeah, doesn't the old magazine article say 95 bhp stock?
                    • MPittma100
                      • Aug 2011
                      • 2359
                      Hp
                      Yes, that 95 HP is engine (at the crankshaft). Normally you get about 85% of crankshaft HP at the rear wheel. That percentage will vary.
                      K&N Air Filter
                      ACCT
                      EBC Front Rotors
                      Mike
                        • 3193
                        Or If one wants to buy a kit there is Amazon http://www.amazon.com/s/ref=nb_sb_no...20kit%20xs1100
                        • dpotter58
                          • Aug 2004
                          • 1866
                          • Southern Maryland
                          Always read the description closely. It does say "1" of each. piston, ring set, ect... not "4" of each.
                          1980 LG
                          1981 LH
                          • rambler Shawn
                            • May 2012
                            • 36
                            • Qualicum Beach, B.C., Canada
                            "The large print giveth, the small print taketh away." -Tom Waits
                            79F cafe
                            • Dan Hodges
                              • Sep 2004
                              • 526
                              73-80 depending on the model.
                                If you just put in early cams with a late head and aren't changing all the timing components and electronics as well... You've just lost a ton of useable HP and created a lead-sled of a bike with zero low end torque. Been there/done that.
                                A fresh engine using the 1179 Wiseco kit, a cleaned up head, 3 angle valve grind, and all new bearings, guides, and seals throughout, Dynojet kit, and stock exhaust resulted in.. a fresh motor with zero percieved HP gains. But.. I had a motor I knew was good to go for a considerable time.
