Gas Leak
Since there is brass already on there, you should continue the repair with it. A crack will continue to grow when heated. Drill a small hole at the end of the crack and continue to braze until sealed. The hole will stop the crack. Use just enough torch heat to melt the brass. A lot of people try to braze with too much heat.
Mike
Originally posted by acc5928
View Post
Mike
