Replacement of Clutch Springs/Plates
    • 3918
    I'm gathering up my shopping list for the bike. I do know that I had some clutch slipping at high speed. So, should I just go ahead and buy the plates and springs and get it over with? If I get into this following TC's great write-up, I'd rather just knock it out instead of leaving things un-done.
    Most everyone finds the friction discs to still be in spec. Just putting the Barnett springs in are usually enough.
    DO NOT USE EBC SPRINGS! They are weak to start with.
      • 3918
      Thanks Nate!
        • 9980
        Springs are usually all it needs Ian. Barnetts are what I recommend. Part # 501-58-06045
        • Tat2demon
          • Jun 2012
          • 718
          • Sioux Falls, South Dakota
          While youre in there you may as well clean up the steels and frictions with some sandpaper. New springs and cleaning plates wont guarantee a fix though. I put in Barnett HD springs, cleaned the plates (still in spec) and it still slips when I get on it hard.
          Nate
          78 XS11 "Matilda" 2H7 000364
          K+N Air Filter
          88 Voyager XII
          81 XJ650 Maxim
            • 9980
            Don't mean to start anything but what kind of oil are you running Tats?
            Any additives?
            • D0wn5h1ft
              • Aug 2013
              • 515
              • Westerly, RI.
              Take a look at these:
              Heavy Duty Clutch Springs
              Replacement Clutch Springs
              Clutch Plate
              The heavy duty ones are on my list.
              78 E - 2to1 exhaust, dynatek coils, special headlight [SOLD!]
              79 F - gas tank refurb, headgasket change, straight pipes, late model carbs, virago lowering shocks, special headlight and gauges, TC fuse block, GSXR-1100 carbs (WIP)
              "May my tires not fail me, nor my engine grow cold"
              • Buckmaster79
                • Nov 2011
                • 98
                • Treynor Iowa
                Clutch
                I also used barnett hd springs and plates with mobile 1 motorcycle
                racing oil and have no problem with slippage and i ride hard.
                79 SF
                  • 9980
                  I use Barnett springs and stock frictions in an engine that came out of an F parts bike from Bob Jones' "pile-o-parts" (the only one out of 8 I bought at the last memorial Bob Jones Memorial Rally that would turn over) with Wally World house brand 20W50 and I CAN'T MAKE the clutch slip.
                    • 8766
                    I've read some fellas put some washers on the clutch bolts to strengthen up the weak springs. That would be the cheapest way. My clutch just started slipping today, hmmm.
                      • 9980
                      Springs are only about $20. http://www.phatperformanceparts.com/...14&Search.y=10
                        • 3918
                        Clutch Plate
                        Yeah, I've read through many posts regarding the EBC springs (including Nate's above), and was advised to stay away from those. They come too short, and are weak. I'll be going for some Barnett springs. Not sure I want HD springs though, as I hate a still clutch, and love the hydraulic clutches on my other bikes.
                          Well, you got a good winter project then, there is a tech tip on converting the XS11 to a hydraulic clutch.
                          • Tat2demon
                            • Jun 2012
                            • 718
                            Any additives?
                            Castrol 20w50
                            Nate
                            K+N Air Filter
                            88 Voyager XII
                            81 XJ650 Maxim
                            • WMarshy
                              • Apr 2009
                              • 2402
                              • Mexico NY
                              I agree with others about Barnett, HD springs are what I used, only notice the stiffer lever for a week or so. Not a problem unless your going to drive 40 miles in stop and go traffic.
                              I also bought cheap friction plates from parts-n-more for about $40 and put them in after I roughed up the stock steels with some ~250 grit sand paper. Clean the grit off with carb cleaner and reassemble. Its been 2 or 3 years now and still no slip, even after countless wheelies.
                              '79 XS11 F
                              Stock except K&N
                              '79 XS11 SF
                              Stock, no title.
                              '84 Chevy K-10 "Big Blue"
