Front Wheel Bearings
  • MPittma100
    • Aug 2011
    • 2359
    Does anyone have a special procedure of getting the front wheel bearings out of the hub? The spacer moves ever so slightly to the side, but does not seem to move enough without some pretty serious forcing.
    Just wondering if there is a procedure.
    Mike
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    • 5050
    From the opposite side, you can use a "drift" or a large, flat screwdriver. You push over the spacer in there to the side to make contact with the race of the bearing with the screwdriver. Give it some wacks and continue with the other edge of the race , walking it dide to side, to push the bearing free. Save the bearing race. Cut a slot through the race and use that to install the new bearing. Save it for future use. You know what to do with the other side...
    • MPittma100
      • Aug 2011
      • 2359
      Bearing Removal
      I have used that method before. Was hoping that there was a less forceful way or a specific bearing tool. But no big deal.
      K&N Air Filter
      ACCT
      EBC Front Rotors
      Mike
      • James England
        • 3039
        • North of England
        I know the rear wheels haves slots cut into the alloy hub to allow a long drift to whack the outer race out from the opposite side of the wheel.
        Although I did my front bearings, I can't remember whether there are slots in the hub like in the rear. Force is the only way, although you can put the new bearings in the freezer overnight and then warm up the front hub with a hair dryer or careful use of a heat gun. This makes the bearings tap in easier. I've always used a socket spanner to tap them in with and smeared a little bit of grease on the outer race. They key is not to let them get lopsided as you tap them in. This makes them difficult, if not impossible to get in. Just make sure that the bearing remains level as you tap it in and you'll be fine.
          The bearings for the front are cheap, no sense working to hard to save them, just replace them.
          ฮผฮฟฮปแฝผฮฝ ฮปฮฑฮฒฮญ
            • 8664
            Yep, there is really no way of getting the first bearing out without striking it in the center area which may/may not damage the bearing, so for sure I wouldn't re-use it.
            โ˜ฎ
              Yup... since the bearings are so cheap, the method is to move that spacer, then beat the **** out of them. Just don't forget to put that spacer back in there before installing new bearings...
              You might already realize this, but I take the old bearings and hit them with the bench grinder to the outside of the race until they easily slide in and out of the wheel hub, then set the old bearing on top of the new one to drive the new one into place.
                Mike
                Hi Mike,
                if you can nudge the spacer sideways enough to get a punch onto the inner race to force the bearing out, great!
                But by doing that you've still scrapped the race.
                If the bastard won't move doing that, do this:-
                Pry out the bearing shield so you can get at the ball cage.
                Dremel the cage rivets off and remove the cage.
                Scoot all the balls to one side, move the race inner to the other side and pull it out. Remove the loose balls with a magnet on a stick.
                Pull the bearing spacer out.
                Now you can get a big fat drift down there to drive the other bearing out.
                • James England
                  • 3039
                  • North of England
                  Having bashed a bearing, I'd never consider using it. Especially not on the front wheel! And, as has been said, the front new are just normal ball bearings and cheap as you like. Bash 'em out, trash 'em if necessary...new ones in! Job done.
                  Usually, they come out easily enough, in fact. Far better a tight interference fit than a loose bearing in the hub!.
                    • 5050
                    Cutting a slot through the race is easy also.
                    • MPittma100
                      • Aug 2011
                      • 2359
                      Wheel Bearings
                      I got them out. You just have to quit treating them like a baby and proceed to thrash. There really should be a better procedure, but Yamaha didn't leave us a lot to work with.
                      I have seen a worse procedure. Back in the day, I know of at least one auto machine shop that kept a wooden stump in the shop. This was their axle bearing removal tool?
                      They would put the axle down on the stump (bearing end), cover it with a cloth, and proceed to bash the living sh_ _ out of the bearing with a sledge hammer!
                      Still can't believe it to this day.
                      Mike
                      K&N Air Filter
                      ACCT
                      EBC Front Rotors
                      Mike
                      • ViperRon
                        • Feb 2011
                        • 1062
                        • Woodstock, VA
                        Get a 5-gallon bucket and a propane torch. Get the new bearing ready to slide in. Move the heat around the aluminum hub of bearing making even heat. When the grease starts to boil put the heated end down over the bucket and lightly tap with screwdriver in other side pushing the spacer to side and the bearing will slide out if it doesnt just drop out. Flip the rim over empty side up and slide in the new bearing by pushing with the handle of screwdriver will probably be enough force. Same procedure for other side. You do not need to heat enough to damage good quality paint but cheap plastic coat may bubble.
                        Or you can always beat the **** out of it depends on needed release of agression
                        Rodan
                        1980 G Silverbird
                        1198 Overbore kit
                        Grizzly 660 ACCT
                        Barnett Clutch Springs
                        R1 Clutch Fiber Plates
                        122.5 Main Jets
                        ACCT Mod
                        Mac 4-2 Flare Tips
                        Antivibe Bar ends
                        Rear trunk add-on
