This is the songggggg that never ennnds ( problems yet again )
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    So over the weekend my friend and I took our bikes to Thunder by the Bay....its a huge motorcycle gathering downtown Sarasota..
    The 28th Annual Thunder by the Bay Music & Motors Festival, Feb 13–15, 2026 at Sarasota Fairgrounds. Benefits Suncoast Charities for Children.
    On the way home...my bike kept dying...it would just, shut off at an intersection...I had lights on neutral and the oil light, so it had power, it just wouldnt turn over using electric start...
    So I would get out my kick starter, kick it over and after two or three itll start up.
    If I killed it from then, electric start will work as normal....
    Till it decides to die at another intersection a couple down...rinse and repeat, it was fine the rest of the night...
    Oh electrical issues.................
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
  • TADracer
    • May 2006
    • 1417
    • Kenner, Louisiana USA
    Not knowing the history of your machine, have you ever cleaned and refurbished all your electrical connections and checked that chassis ground wire?
    Mike Giroir
    79 XS-1100 Special
      So when hot it would simply not turn over at all? Or did it turn over fine when hot, just not when it died on you?
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        I have cleaned 99% of the connections I come across...
        It will turn over hot no problem at all...it just wont turn over ONLY when it decides to die on me randomly..
        79F
        "Excelsior"
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        TC fuse block
        Raptor 660 Acct
          • 9981
          Sounds like a kill switch or ignition switch loosing contact. Most likely the kill switch from the sound of it.
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            To bypass the kill, what would I have to do, just to see if it works?
            I'm terrible at wiring...
            I only use the key ignition anyway....so if the kill switch is bad...no biggy to me!
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
              • 8893
              Had a similar issue, bike would shut off randomly at any time and would crank but not start. After a few minutes of pushing bike to the side of the road, bike would start. Finally traced it down to the wire harness for the P/U coils that ran under the rear of the engine up to the connector in back of the fuse panel. Turns out the harness had a wire with a break in it near where all the heat from the exhaust was. Once I replaced that harness, problem went away forever. JAT, GL
                • 9981
                Open the sheathing near the switch and find the 2 large red/white stripe wires and connect them together. I fond that running a safety pin through the center of them connecting them to be the easiest way to test without taking the switch apartor cutting the wires.
                  I could see an intermittent key switch or kill switch making it die, but either one of them would not let the starter turn over if they continued to be a problem.
                  I am almost thinking bad ballast resistor, intermittent problem?? Although I would suspect those to be good or bad and not come and go.
                    • 9981
                    This is what points toward the kill switch.
                    • D0wn5h1ft
                      • Aug 2013
                      • 515
                      • Westerly, RI.
                      Just unplug the kill switch completely. Remove it from the bike, that's what I did. I always take those things out. Out of the two XS11s I've had they both had sticky kill switches anyways so it's not like it was doing it's job anyways.
                      It would seem, according to BA80's recommendation that it needs to be shorted to work...however, I just unplugged mine and the bike runs just fine. Wonder why that is?
                      No killswitch, no problems.
                      78 E - 2to1 exhaust, dynatek coils, special headlight [SOLD!]
                      79 F - gas tank refurb, headgasket change, straight pipes, late model carbs, virago lowering shocks, special headlight and gauges, TC fuse block, GSXR-1100 carbs (WIP)
                      "May my tires not fail me, nor my engine grow cold"
                        • 2098
                        JAT If you still have the old fuse box (bottle type) this may be your problem.
                        The same symptoms are happening on my XJ 750 as I have yet to update the fuse box.
                        HTH
                        Edit: Just saw you have TC's Fuse box mod.
                          Check the plug from the handlebar controls; it's under tank. I've had issues with the individual contacts being 'loose' in the plug, make sure the female half is tight on the male side.
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            I'm going to bring some tools home from work, and take excelsior apart, once more.........
                            Hope some of these suggestions work
                            79F
                            "Excelsior"
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            TC fuse block
                            Raptor 660 Acct
                              I'll note this is more of a problem on the '78-79 bikes, Yamaha changed the plug style in '80, probably to fix this issue....
