This is the songggggg that never ennnds ( problems yet again )
    Originally posted by D0wn5h1ft
    Just unplug the kill switch completely. Remove it from the bike, that's what I did. I always take those things out. Out of the two XS11s I've had they both had sticky kill switches anyways so it's not like it was doing it's job anyways.
    It would seem, according to BA80's recommendation that it needs to be shorted to work...however, I just unplugged mine and the bike runs just fine. Wonder why that is?
    No killswitch, no problems.
    I suspect there are two different switches being referred to here. The run /stop / run switch on the right handlebar completes the circuit that lets the engine run. it has to make a connection of the two wires for the bike to run, or the starter to turn.
    The tipover switch (also known as the kill switch) shorts the ignition circuit to kill the engine in case of a tip over. This is located under the gas tank. It can be simply unplugged and removed and everything will work, except the engine will not die if the bike is layed down. Which can be dangerous.
    • rpgoerlich
      • Dec 2007
      • 643
      • Katy, Tx
      Check the plug from the handlebar controls; it's under tank. I've had issues with the individual contacts being 'loose' in the plug, make sure the female half is tight on the male side.
      +1, found this plug pulled loose on my 79SF a few times, finally tie wrapped it together.
      Richard
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        Well, I went through the rest of the electronics behind the fuse box area and found some of the connections a bit nasty...cleaned em up, organized it a bit more.
        Unplugged the "flip over" sensor....kill thingy..
        And bypassed the kill switch on the handlebar.
        Havent had a single electrical issue since
        79F
        "Excelsior"
        Honda gl1100 handlebar
        Vetter IV fairing with speaker system
        OE headers,Jardine slipons
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        Oe hardbags and luggage rack
        TC fuse block
        K&n filter with oe airbox
        Raptor 660 Acct
          So, now which one was the issue? My suggestion is to clean the handlebar kill switch and get it back on line. It is a safety device.
