Bad Oil Filter Bolts
  • tweeleft
    • May 2009
    • 110
    • Bend Oregon
    Hello Gang
    I got a issue with "The Winter Project". Seem the oil filter bolt is rounded, and the PO cut a slot for a flat blade but it won't budge. Has anyone had to cut their filter housing to remove the bolt?
    Keep the shiny side up
    1979 XS1100SF
    Mac 4-1
    Drilled airbox Uni filter
    Vmax bars
    Virago 1" shorter shocks
    30K miles
    http://i1228.photobucket.com/albums/...429_135845.jpg
    1981XS1100SH
    '80 G Forks and Triple Tree
    '80 G tank
    Mac Turnouts
    Virago 1" shorter rear shocks
    SH Headlight
    http://i1228.photobucket.com/albums/...psd6adaae1.jpg
    61 Wife
    83 Son
    86 Son
    89 Daughter
    So you've tried the usual vice grips, pipe wrench, etc? If/when you get it off, Partsnmore.com has new ones for $17.
      If you can get the bolt out without completely trashing it, they can be repaired and eliminate the problem of the too-small bolt head.
      I've turned the existing head down to 1/2", reversed a 1/2" die and cut a short thread on it. Thread on a 1/2" nut (3/4"/19mm head) then braze the nut on. You do need to remove the check valve to do this so the heat doesn't destroy the spring, but you now have a larger head with better leverage for removal...
      If you don't want to do this, always use a 6-point socket to change the filter, that helps a bunch....
        • 7768
        A torque wrench isn't a bad idea either.
        • MPittma100
          • Aug 2011
          • 2359
          Oil Filter Bolt
          Definitely replace it or modify as suggested. If there is enough of the bolt head left, a stud remover tool might work.
          May have to spot weld a nut onto the existing bolt head if all else fails.
          Mike
          1981 XS1100H Venturer
          K&N Air Filter
          ACCT
          Custom Paint by Deitz
          Geezer Rectifier/Regulator
          Stebel Nautilus Horn
          EBC Front Rotors
          Limie Accent Moves On In 2015
          Mike
          • tweeleft
            • May 2009
            • 110
            • Bend Oregon
            Thx, Guys
            I do have the replacement parts. Was thinking I'd have to cut around the bolt to releive the pressure and spin it out. I'll see about a welder
            1979 XS1100SF
            Mac 4-1
            Vmax bars
            30K miles
            1981XS1100SH
            '80 G tank
            Mac Turnouts
            SH Headlight
            61 Wife
            83 Son
            86 Son
            89 Daughter
            • RUSH
              • Feb 2005
              • 214
              • Lake Stevens, WA
              Get yourself a wood chisel and a hammer.
              Use the chisel and hammer to break the bolt loose. Hit in the direction to unscrew the bolt.
              First bike was an: 1978 XS1100
              Second bike is an FJR1300.
              Now I'm restoring a '79 XS1100.
              • tweeleft
                • May 2009
                • 110
                • Bend Oregon
                Thx Guys. Got it with the old hammer and chizel
                1979 XS1100SF
                Mac 4-1
                Vmax bars
                30K miles
                1981XS1100SH
                '80 G tank
                Mac Turnouts
                SH Headlight
                61 Wife
                83 Son
                86 Son
                89 Daughter
                • Yahman
                  • Mar 2008
                  • 779
                  • Salem, OR
                  Not to change the subject, but is that a XJ seat on your XS?
                  I hate the seat on my XJ, most uncomfortable seat I've ever had on a motorcycle. I picked up another seat pan and I'm in the process of modifying it. Hopefully it will be better when I get done.
                  Ride safe,
                  Larry
                  82 XJ1100
                  80 XS1100G (Project bike)
                  64 Yamaha YA-6
                  77 Suzuki TS-185
                    You'd never get a XJ seat to fit without extensive mods to both the seat and the frame, but that may be a XJ cover on a XS seat....
                    • JCW
                      • Jan 2014
                      • 11
                      • Chicago, Il
                      Mike
                      I've welded larger nuts to oil filter bolts on all my old bikes.
                      Seems like one of the requisites for all the used bikes I buy is overtorqued oil filter bolt with rounded off the edges.
                      XS850
