XS1100G Seat Question
  • Hideki
    • 85
    • West Hills, CA
    I am trying to restore a 1980 XS11G and I'm looking for the correct seat. It is not a special model - bigger real wheel and had the longer exhaust pipes, but my tank looks like a special tank and not a standard... I'm actually confused to what the difference in XS11G tanks is? I see the earlier model standard tanks have slab sides and specials are teardrop shaped, are all 1980 tanks tear dropped shaped? I'm asking because I want to know what seat/side covers I should be hunting down? With that said if you have the correct seat I'm interested
    The standard tanks all look the same (except the '81 h is a little taller) and all the special tanks look the same. The standard and special tanks interchange but the seat doesn't look right where it meets the tank.
    • Gallaecus
      • May 2011
      • 254
      • East Haven Connecticut
      goto xs11.com FORUMS..... under REPAIR section....there is an interchange guide
      then goto xs11.com forums......Miscellaneous....Miscellaneous tip...is your serial number identification guide.
      post what you want in the buy sell trade forum ....wanted to buy...
      then seach the parts for sale forum for your part...
      hope that helps
      Steven
      1981 XS 1100 LH
      1979 XS 1100 SF
        Hey Hideki, Your not putting that cool mod bike you assembled back to stock are you? You did a great job on that unique creation.
        As Nate indicated, all Standard tanks have the knee indents, stand up taller, almost squarish look to them. All Special tanks have that tear drop look (Special model was the move toward V-Twin look-a-likes). Sounds like someone swapped a special tank on your Standard.
        The Seats is an area that gets more unique year to year and model to model. So I think the G seat is a one of. The 78-79 models had the rear seat cowl, and the H model I believe had a different frame as it uses Special exhaust and foot peg brackets.
          Special
          standard
            Also if you use the mongo tank from the 81H you need the taller bars to clear the tank. (In case you go shopping for a tank)
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              Not exactly true. The 81 standand (H) has the same handlebars as the other standards. (same part number) You may need to adjust them to tilt up a little.
              I put my G bars on my H and I need to tilt them up a little because the hazard switch just touches the tank at full turn.
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
                That is surprising. It could be that my two 81E's had after-market bars. I am not the original owner of any of my bikes. When I put the 81H tank on the 78E, I had to tilt the bars at an angle beyond horizontal. For me it was unsightly and bad on the wrists...
                • GLoweVA
                  • Jun 2011
                  • 1957
                  I just got my H a few months ago and it had sport bars on it. (too small)
                  I put my G bars on it so it'd be somewhat normal.
                  Then I started seeing on the site about the H bars were different, and I thought maybe so, so I looked up the part numbers and viola, they are the same for all the standards.
                  I may end up getting risers or maybe some special bars to be able sit back a little more in the seat.
                  The Green Monster
                  Got him in '04.
                  Scarlet
                  Got her in '11
                  Hugo
                  Cold weather ride
                    Oops! That should have read, "It could be that my two 78E's.."
                    sorry. I am the worst proof-reader on the planet.
                      Originally posted by GLoweVA
                      ..Then I started seeing on the site about the H bars were different, and I thought maybe so, so I looked up the part numbers and viola, they are the same for all the standards..
                      The H did have different bars from the factory. The thing to remember about the parts fiche is that is showing service replacement parts, not necessarily what was installed on the production line. You will find some bits listed as replacements that aren't exact duplicates of OEM, but will fit/function 'close enough' that Yamaha deleted the earlier version.
                      • GLoweVA
                        • Jun 2011
                        • 1957
                        So Steve, you're telling me that there does exist bars that are supposed to be for the H?
                        If the other standard bars are good enough to fit, i wonder how different they are
                        The Green Monster
                        Got him in '04.
                        Scarlet
                        Got her in '11
                        Hugo
                        Cold weather ride
                          The H did have slightly different bars as OEM; I remember them because of a conversation with a parts guy when they were introduced. IIRC, they had a bit more rise and were just a bit wider, but the same pullback.
                          Now, which 'version' they used as the service replacement is anybody's guess, although it was usually the newest one. Not an issue unless you're trying to do a 'perfect' restore, but there was more 'detail' differences between years than most realize....
                          • Hideki
                            • 85
                            • West Hills, CA
                            Thanks for answering my questions, appears while the bike vin states it's a standard, someone had to of replaced the tank with a special tank. Now, does anyone have a 1980 special seat for sale (hopefully cheap)
                              Did you mean the Standard seat? I would need to refer to the interchange guide if the Special seat fits on the Standard.
                              If you are looking for a Special seat, the 80 or 81 Special seats will freely interchange and are all but identical as well.
