Slide diaphragm conditioner?
  • Eastcoaster
    • Jan 2012
    • 508
    • oceancity NJ
    Working on some carbs tonight no pin holes in the diaphragms but feel a little stiff. Has anyone ever used any type of conditioner on them like an armor all?
    82 XJ1100J
    81 Venturer
    Would not apply anything to them. They'll work just fine.
      • 8061
      I concur with Motoman. Nothing will be fine. You can put baby oil on them if you wish. It will condition vinyl and rubber if you keep using it.
      • Ken Talbot
        • 4251
        • Revelstoke, BC
        If anything, I would go with a dab of brake fluid rather than an armour-all type product. Stay away from any sort of grease on rubber.
        Ken Talbot
        • MPittma100
          • Aug 2011
          • 2359
          Carb Diaphragms
          It is cold out and rubber is stiff. Other than warmer temperatures, they don't need any help.
          1981 XS1100H Venturer
          K&N Air Filter
          ACCT
          Custom Paint by Deitz
          Geezer Rectifier/Regulator
          Stebel Nautilus Horn
          EBC Front Rotors
          Limie Accent Moves On In 2015
          Mike
            • 2097
            A little 303 Aerospace protectant wouldn't hurt on the original diaphragms.
            On my new diaphragms, I used a little silicone grease around the edge where the bulb fits into the groove.
            Also I burnished the sharp edge, on the inside top of the carb body, that the diaphragm contacts. That's the place my old diaphragms had pin holes.
            HTH
              HTH
              +1 on the 303Aerospace re-juvinate and conditioner!.........you;ll never get near another Armoural product!
              For this app. with fuel fumes continuious presence, doubtfull they'd be any real effect for any gained durability. The OEM diaphrams are of a silk material which are then coated.
